JDM SIDEMARKERS
http://www.g2ic.com/tegtips/lighting/18.html
That should help you out a bit but, I advise you search first
*cut a rectangle shaped hole where you want them to be, making sure the hole comphensates for the mounting tabs on the sidemarker itself
*splice into the turn signal wires on the corners, noting the polarity of the wires, and make them long enough to reach the connection on the side marker
*snap it in, throw the splashguard on if you took it off in the first place, and bam!
If you do happen to find a step by step tutorial with pictures, which I think is what you're looking for, make sure your sidemarker matches the one being installed in terms of dimensions.
KRZRICAN
Feb 4, 2009 07:51 AM
D16 madwoman
Dec 1, 2003 05:35 AM
