Help with door
ok i know that 88 crx's have the seatbelts mounted in the pillar, in 89 if the rex was a dx or si then the belts were in the door, but if it was an hf then it was pillar mounted. if it was a 90-91 then they are all mounted inn the door.
with that said i have a 89 hf, will a 88 door fit on my car with no problems? i have tried a door with the belts in the door and that was a disaster. i will not work unless you beat both the door and the body in on certain areas. thanks for the answers
B2FiNiTY
20
Dec 13, 2003 09:46 AM
