Suspension & Brakes Theory, alignment, spring rates....
Comptech Rear Sway/Tie Bar + Apexi N1 catback Question
Old Mar 6, 2005 | 06:17 PM
ANDREW D's Avatar
Default Comptech Rear Sway/Tie Bar + Apexi N1 catback Question
Will the Comptech rear Sway/Tie bar fit with a Apex N1 exhaust???
Old Mar 6, 2005 | 06:20 PM
nadc2's Avatar
Default Re: Comptech Rear Sway/Tie Bar + Apexi N1 catback Question (ANDREW D)
bump this up.... not to thread jack, but will the comptech setup fit w/ a mugen twinloop as well?
Old Mar 7, 2005 | 12:14 PM
ANDREW D's Avatar
Default Re: Comptech Rear Sway/Tie Bar + Apexi N1 catback Question (nadc2)
on up...................
Old Mar 7, 2005 | 01:33 PM
n1ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nadc2 &raquo;</TD></TR><TR><TD CLASS="quote">bump this up.... not to thread jack, but will the comptech setup fit w/ a mugen twinloop as well? </TD></TR></TABLE>
My friend had an EK with a twinloop and a comptech bar, worked fine.
Apex N1 I don't know about....since the piping is not in same orientation as the stock muffler.
Old Mar 8, 2005 | 08:55 PM
BLUE EH3's Avatar
Help we my pennies
im a planning on getting the srr sway/tie bar kit. i just order a N1 muffler. i want my muffler put on with a big slant (jdm) when my question is the muffler going to hit/ or cause conflict with my swap bar? or should i get the bar first and have the muffler place work around it
Old Mar 9, 2005 | 05:32 AM
ANDREW D's Avatar
Why is everyone whoring up this thread?! Not to be a dick but, start your own thread!
Old Mar 9, 2005 | 06:28 AM
BLUE EH3's Avatar
Help we my pennies
drew, are u using the apex stock piping?
Old Mar 9, 2005 | 12:15 PM
ANDREW D's Avatar
Default Re: Comptech Rear Sway/Tie Bar + Apexi N1 catback Question (BLUE EH3)
Yes, its a Apex N1 Cat-back.
Old Mar 9, 2005 | 07:31 PM
redrum eg6's Avatar
on my 92 hatch my n1 is very close to the underside of the rear subframe where the lca bolts into it, as it goes underneath it (closest on the side of the subframe facing the the front of the car). it looks like it would hit the brace for the swaybar, unless you ground off some of it.
Tage Evanson
Jun 9, 2006 10:33 PM
ANDREW D
Mar 17, 2005 05:30 AM
Dodger2940
Apr 30, 2002 02:42 PM
