most likely cause of over heating?
Old Mar 6, 2005 | 02:32 PM
White86CRXSi's Avatar
Default most likely cause of over heating?
ok well its a stock 86 crx si... over heating again.. was headgasket last time and im thinking it could be that again but my thermostat housing is held together with vise grips so ... what do you people think? break it down change head gaskets again? or what .. i also have a friend with a b18 for sale with an auto tranny and motor mounts for 200 bucks but auto tranny how would i go about getting a manual? help please
Old Mar 6, 2005 | 02:37 PM
EP3_05's Avatar
Default Re: most likely cause of over heating? (White86CRXSi)
Are you burning coolant? Is the oil mixing in with the coolant?
For the b18 you will need to source a b series cable type 5spd transmission
Old Mar 6, 2005 | 02:49 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
The cooling system also must be able to hold pressure..
at least 13 p.s.i.,Otherwise,it will most likely overheat.
[Water under pressure has a much higher boiling point..]
I'm guessing yours may not.
Old Mar 6, 2005 | 02:51 PM
Churched's Avatar
Have you changed the actual thermostat? I would try that then see whats up.
Old Mar 25, 2005 | 05:29 PM
Default Re: (Churched)
Well, Lol Solved My Over Heating Problem.. Drove It Down The Road And Back Cause Ive Missed It So Much And On The Way Back, 2nd Gears, Neating 6 Grand and Pow.. Slung A Rod Threw The Block It Was Hanging About Half Way Out The 4 inch diameter Hole it Made
Old Mar 25, 2005 | 05:39 PM
FalkenSiR's Avatar
Default Re: (White86CRXSi)
NICE!!!!!!!!!!!!!
j/k...lol. Yea, usually ull lose a lot of power dunno why, just happens... BTW, sucks to hear that man. Well, time to start with a better engine
Why The Capitals At The Beginning Of Each Word?
Old Mar 25, 2005 | 09:57 PM
Default Re: (fast88std)
I Don't Really Know, I Seen Somone Doing It And It Looks Cool To Me, Lol, I've Gotten Used To Typing Like This Too, So Oh Well
Old Apr 5, 2005 | 06:18 AM
twin336's Avatar
HEY WHATSUP ALL. IM ABOUT TOO BUY A ACURA LEGEND 91.THE GUY THAT IM GOING TO BUY IT FROM SAYS THE CAR OVERHEATS WHEN YOU STOP AT A LIGHT OR A STOP SIGN.BUT HE SAYS WHEN U DRIVE THE CAR ON THE HIGHWAY ITS OK. WHAT DO U THINK IT IS? WHAT IS THE SIGN OF A BAD HEAD GASKET? THANKS
Old Apr 5, 2005 | 09:18 AM
Sequoyah's Avatar
Default Re: (twin336)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twin336 &raquo;</TD></TR><TR><TD CLASS="quote">HEY WHATSUP ALL. IM ABOUT TOO BUY A ACURA LEGEND 91.THE GUY THAT IM GOING TO BUY IT FROM SAYS THE CAR OVERHEATS WHEN YOU STOP AT A LIGHT OR A STOP SIGN.BUT HE SAYS WHEN U DRIVE THE CAR ON THE HIGHWAY ITS OK. WHAT DO U THINK IT IS? WHAT IS THE SIGN OF A BAD HEAD GASKET? THANKS
That sounds about right. Buy it before someone else does
Old Apr 5, 2005 | 11:20 AM
twin336's Avatar
Default Re: (Sequoyah)
SO U THINK ITS THE HEAD GASKET?
Old Apr 5, 2005 | 11:22 AM
twin336's Avatar
OR COULD IT BE THE COOLANT TEMPERATURE GAUGE SENDING UNIT?
Old Apr 5, 2005 | 11:28 AM
Keith P's Avatar
Does the fan kick on?
Old Apr 5, 2005 | 11:58 PM
whiteef-8's Avatar
Default Re: (Keith P)
yea, my crx does the same, but i have no fan , that could be it huh?
BigJerm333
12
Aug 5, 2014 08:01 AM
fiftyOne
Oct 17, 2012 02:56 PM
bandit080000
Honda Civic (2001 - 2005)
Jul 1, 2010 11:09 AM
D16Z6_turbo
Sep 10, 2006 08:57 PM
dip-set
Apr 14, 2005 04:51 AM
