Ball joints and white lithium grease
My ball joints are split open and dried out, soo today when I had the car jacked up I sprayed white lithium grease inside... Is this ok? I plan on replacing the ball joints in a month.
white lithium is not made for ball joints but if there is no or very little play you should be good for another month, just replace them ASAP ball joints keep your wheel connected. and yeah i guess some grease is better then none.
Now you're gonna have to replace them. Before you might have got away with only replacing the rubber boots?? Upper balljoint usually means you have to buy the upper control arm.
For $5 you could've bought the right grease... But maybe the joints themselves were already damaged (loose?) before you noticed the torn boots.
