running higher compression pistons, best way to tune
i will be getting another sohc motor this weekend, and im going to put in d16a pistons from an integra. it should yeild 11.1-11.5 CR depending on what headgasket i use. whats the best way to make this motor not lean out. i was told a FPR would be good. is this true? i want to stay odb0 so what can i do?
You can run turboedit or just run a vafc and an fpr. I am pretty sure the stock injectors will be fine since the b series engines run the same flow injectors(240cc) as the d series engines do. 11-11.5:1 compression is not too high. Just remember to run premium fuel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noah ***** »</TD></TR><TR><TD CLASS="quote">vafc or just afc? its not a vtec head</TD></TR></TABLE>
Ah my bad, I meant afc...
yusoslo
Oct 9, 2003 08:14 PM
MikeMAN
12
Jun 20, 2003 06:48 PM
ls_vtec_b18a1
Jan 22, 2003 05:10 PM
shortdahri
Mar 25, 2002 08:49 PM
