OBDII injector clips, is there a positive and negative?
When I swapped out my stock injectors for some 550s, I put on some OBDI injector clips and they didn't have a positive and negative on them so you could soder them up anyway you wanted. Now I am sodering back up my OBDII injector clips and am wondering if they have a positive and negative or if i can soder them up anyway i want? Thanks.
Pfieff
Pfieff
I think all that matters is that they are all wired the same(uniform).
Different car car but similar situation.
I installed a supercharger, piggy back ecu, fuel pump and some larger injectors in a friends TRD Tacoma
When I was soldering the clips onto the harness the instructions in the kit said that (+/-) didn't really matter just make them all uniform.
Truck runs great and it started on the first crank.
Panoply
Jul 18, 2005 09:36 AM
