2.5 vs. 2.25" piping with jun 3 cams
Old Jan 21, 2002 | 10:50 PM
Mr. Softee's Avatar
Default 2.5 vs. 2.25" piping with jun 3 cams
i have a 12:5 compression, jdm itr header, jun 3 cam itr... and am considering either getting a new 2.25" exhaust from teh header back... or 2.5" piping to a 2.25" muffler... or 2.5" piping back. The thing is... the only reason id even consider the smaller piping is because:
i can get an itr catback for cheap
i like a quiet exhaust
im low on cash
so... how much performance gains do you think id lose with teh small piping... or just small muffler.
Old Jan 22, 2002 | 05:21 AM
Leo95SE's Avatar
Default Re: 2.5 vs. 2.25" piping with jun 3 cams (94goldjungsr)
jun recommends 3" straight through. lol.
id stick with 2.5"... prob is youll lose even more low end then with 2.25"..i guess it just depends on the application.
Old Jan 22, 2002 | 05:45 AM
BoM's Avatar
BoM
Default Re: 2.5 vs. 2.25" piping with jun 3 cams (Leo95SE)
i'd say stick with any catback exhaust system thats 60mm
which is bigger than 2.25 inches just a tad.
when u go to a bigger bore as in 84mm+++
then it'll be time to go with a bigger exhaust for more gases your burning
2.5 inches would be needed than
Old Jan 22, 2002 | 06:22 AM
SMSP's Avatar
Do your exhaust once. It will be cheaper in the long run. If you don't have the money for a 2-1/2" system now, just stock with what you got but at a minimum get rid of that bottle neck, especially if you are running a JDM header.
Old Jan 22, 2002 | 06:38 AM
HX_Guy's Avatar
Sam, the ITR system is more like 2", not 2.25"
azn98R's Avatar
Default Re: 2.5 vs. 2.25" piping with jun 3 cams (SMSP)
I was running into the same question...I have 60 mm piping exhaust w/ JDM header & test pipe. I was thinking of re piping it to 2.5, but still wouldn't there be a bottleneck where the piping meets the muffler? Would that be just as bad?
Old Jan 22, 2002 | 03:43 PM
Mr. Softee's Avatar
Default Re: 2.5 vs. 2.25" piping with jun 3 cams (azn98R)
well igot a full itr exhaust for 150$... so im gona use that
TheKid1488
Jul 1, 2008 04:55 PM
rough_draft
Apr 27, 2004 08:58 PM
Rory Breaker
Dec 11, 2002 10:43 AM
96tegsr
Oct 18, 2002 01:32 AM
eTec
15
May 21, 2002 02:00 PM
