FS - Wastegate Spring: 1 bar/Big Blue
Old Mar 6, 2005 | 09:23 AM
GaRn's Avatar
Default FS - Wastegate Spring: 1 bar/Big Blue
I have a wastegate spring for a Tial WG or any wastegate that accepts 1.875" OD springs..
This spring is a 1 bar/14.5 psi spring
It has never been used, I took it directly out of my wastegate!
pic..
$20 shipped obo
Ebay ID: garnxe, I have over 40 feedback, ALL positive..
Old Mar 6, 2005 | 02:37 PM
Kutsuju_SLeePER's Avatar
Default Re: FS - Wastegate Spring: 1 bar/Big Blue (GaRn)
you can still run 10 PSI if you wanted to right?
what size WG did it come off of?
Will it fit a 35 MM one?
Old Mar 6, 2005 | 03:18 PM
GaRn's Avatar
Default Re: FS - Wastegate Spring: 1 bar/Big Blue (Kutsuju_SLeePER)
with a boost controller or an adjustable WG you could run 15 psi or up, but not lower..
it will fit a 35mm/38mm/40mm/44mm/46mm tial, but it will be different psi's for the same spring for some different models..
http://tialsport.com/gates.html
Old Mar 6, 2005 | 03:19 PM
MooreBoost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kutsuju_SLeePER &raquo;</TD></TR><TR><TD CLASS="quote">you can still run 10 PSI if you wanted to right?
No, you can only go higher than your spring.
Old Mar 6, 2005 | 04:21 PM
Default Re: FS - Wastegate Spring: 1 bar/Big Blue (MooreBoost)
thanks....
Bump
Old Mar 6, 2005 | 04:29 PM
kabaroo's Avatar
i just swapped out my blue 1 bar spring. It looks nothing like the spring pictures. Mine had more coils, at least 6-7.
You sure its a 1 bar?
Old Mar 6, 2005 | 08:35 PM
GaRn's Avatar
Default Re: FS - Wastegate Spring: 1 bar/Big Blue (kabaroo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kabaroo &raquo;</TD></TR><TR><TD CLASS="quote">i just swapped out my blue 1 bar spring. It looks nothing like the spring pictures. Mine had more coils, at least 6-7.
You sure its a 1 bar?</TD></TR></TABLE>
Hey,
yea I am sure, it is not a Tial WG spring but it has the same dimensions, its from a Progate.. a $399 wastegate, and it is 15 psi, waaay to much for what I need..
Old Mar 7, 2005 | 07:04 AM
kabaroo's Avatar
^^ well that makes sense.
ladysman
Jun 11, 2007 01:03 PM
TURBODC4TEG
Dec 1, 2006 02:53 AM
sPaRk'iT
Sep 10, 2004 10:16 PM
xstalkrx
Jun 29, 2004 04:47 AM
slammin86
May 26, 2004 04:55 PM
