ECU Wiring Diagram
Old Mar 6, 2005 | 09:06 AM
hotinteggy's Avatar
Default ECU Wiring Diagram
I just recently replaced my 0xygen sensor which made my air/fuel guage quit working. I was wondering if anybody knew where i could find the wiring diagram for the ECU so i could hook the guage up where it needs to be in the first place.
Thanks
Old Mar 6, 2005 | 09:16 AM
gsrious's Avatar
Default Re: ECU Wiring Diagram (hotinteggy)
go to teamintegra.net to find out. they should have it there.
Old Mar 6, 2005 | 09:27 AM
hotinteggy's Avatar
Default Re: ECU Wiring Diagram (red dc2)
thanks
Old Mar 6, 2005 | 09:46 AM
3.504's Avatar
you'd have to tell us what year car. for obd1 i believe its slot d14
Old Mar 6, 2005 | 03:57 PM
hotinteggy's Avatar
Default Re: ECU Wiring Diagram (3.504)
92 LS
Any idea the wire color?
Old Mar 6, 2005 | 04:12 PM
3.504's Avatar
this should help you some, the "a" connector is the connector on the bottom of the bottom picture all the way to the left, b is in the middle, d is on the right. the pins read a1 is top left of the connector, a2 is bottom left, a3 is top 1 over right from a1, a4 is bottom one over right from a2. and it reads for all connectors like this.
d14 is the slot you need to tap into, go get a wire tap and start counting connector pins
Modified by 3.504 at 10:03 PM 3/6/2005
Old Mar 13, 2005 | 09:36 AM
hotinteggy's Avatar
pics didnt load
haroldthefly91crx
Aug 24, 2007 07:25 AM
FBPninetynineEM1
Mar 19, 2003 09:16 AM
