driver side axel problem
Old Mar 6, 2005 | 04:39 AM
Mleach's Avatar
Default driver side axel problem
The passenger side popped out of the case, just like it said it would in the manual. I got to the driver side, followed procedure, balljoint is free, axle is only engaged at the intermediate shaft. I can not get it to pop out for the life of me. Does anyone have any suggestions? This is killing me.
matt
Old Mar 6, 2005 | 04:47 AM
the niz jiz's Avatar
Default Re: driver side axel problem (Mleach)
car specs?
Old Mar 6, 2005 | 05:15 AM
CUSTOMCONNECTION's Avatar
had simular problem couple weeks ago with friends car...ended up takein axle and mid shaft both to local cv axle shop and they finaly got it apart..
Old Mar 6, 2005 | 06:57 AM
Cory man's Avatar
Default Re: driver side axel problem (CUSTOMCONNECTION)
Since you are saying you have tried everything, I assume you have attempted to hammer on the inner jt and also have used a long prybar as well. If those dont work then you may have to cut the inner boot off and pull the bearings out and leave the inner joint in the trans. Good Luck!
spotrep
Transmission & Drivetrain
Jan 24, 2013 06:54 PM
t3601
Dec 3, 2009 01:53 PM
B16-CRX
Aug 5, 2009 09:16 AM
jdm94accord
Jan 11, 2007 07:22 AM
Joe...
Dec 29, 2006 06:54 PM
