need advice
Old Mar 6, 2005 | 01:48 AM
2k.civic.si's Avatar
Default need advice
whats with the ring of buildup around the top of my cylinder walls ?
ya im running rich...i know this
Old Mar 6, 2005 | 11:33 AM
pontiac power's Avatar
Default Re: need advice (2k.civic.si)
it is normal, the piston rings don't reach up to the top of the cylinders, that is why you get those marks
Old Mar 6, 2005 | 12:50 PM
Default Re: need advice (pontiac power)
sweet...so all looks well?
Old Mar 6, 2005 | 01:04 PM
with the exception of it running rich, yes
EDIT: although you are missing a head stud in the picture
Modified by pontiac power at 5:15 PM 3/6/2005
Old Mar 6, 2005 | 01:26 PM
5STAR3's Avatar
what is your set up?
Old Mar 6, 2005 | 01:48 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si &raquo;</TD></TR><TR><TD CLASS="quote">sweet...so all looks well?</TD></TR></TABLE>
Looks like it ran rich as hell.
Old Mar 6, 2005 | 03:35 PM
Default Re: need advice (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
Looks like it ran rich as hell.</TD></TR></TABLE>
it was also burning a lot of oil due to bad valve seals...so im sure that didnt help that buildup on the pistons
Old Mar 6, 2005 | 03:53 PM
Hybrid96EK's Avatar
it was also burning a lot of oil due to bad valve seals...so im sure that didnt help that buildup on the pistons</TD></TR></TABLE>
The build up isn't what indicates a rich burn. Its the clean *** intake side of the pistons that show the excess amount of fuel washing the cylinders.
Old Mar 6, 2005 | 07:45 PM
The build up isn't what indicates a rich burn. Its the clean *** intake side of the pistons that show the excess amount of fuel washing the cylinders.</TD></TR></TABLE>
*nods*
Old Mar 6, 2005 | 08:40 PM
milruner's Avatar
Dude whats your set up looks cool man. Looks like a B18c1 bottom block and Over sized CTR pistons. you are missing one head bolt where it at hope you find it.
JK Artie tell me when you need to put it back togethere and i will do so. I had fun pulling it apart.
MIKE
Old Mar 6, 2005 | 09:11 PM
Default Re: need advice (milruner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milruner &raquo;</TD></TR><TR><TD CLASS="quote">Dude whats your set up looks cool man. Looks like a B18c1 bottom block and Over sized CTR pistons. you are missing one head bolt where it at hope you find it.
MIKE</TD></TR></TABLE>
DOHC_C-REX
Jun 8, 2008 04:29 PM
pornstar4777
Feb 14, 2008 12:47 PM
TrnsferErr
19
Jan 22, 2006 05:53 PM
doublejz
Oct 4, 2005 01:27 PM
potator
Apr 17, 2005 06:59 PM
