EG Seats into an EF?
Old Mar 5, 2005 | 08:55 PM
bigslimdog's Avatar
Default EG Seats into an EF?
I just got a '90 hatch and the seats are pretty ripped up. I figured I could put my stock seats from my '94 EX in there to replace the messed up ones. What do I need to do as far as swapping the rails and stuff? Which rails should I use?
Old Mar 6, 2005 | 01:37 AM
eda6's Avatar
Default Re: EG Seats into an EF? (bigslimdog)
I tried this Christmas Day. Attempted a seat pan swap and realized it wasn't going to happen. I noticed that the eg pan is wider and the rails were longer.
You need to weld your existing brackets to the eg seats and reuse the hatch mouting points.
Seemed that the eg seats would sit higher as well.
Old Mar 6, 2005 | 02:28 AM
88 rex's Avatar
Default Re: EG Seats into an EF? (eda6)
I had eg seats in my old 86 rex. They were in it when i got it Wish i could tell you exactly how they were put in.
Old Mar 6, 2005 | 07:06 AM
bigslimdog's Avatar
Default Re: EG Seats into an EF? (88 rex)
bump for more ideas
Old Mar 6, 2005 | 01:51 PM
trooper0641's Avatar
EG seats sits waaay to high for a ef. When you get into a accident...your head is going to hit the top of the glass or even higher, and your going to end up having your neck snapped in half. So I advised you not to do it.
Old Mar 6, 2005 | 02:00 PM
bigslimdog's Avatar
Default Re: EG Seats into an EF? (trooper0641)
Would some welding and cutting fix the height issue?
Old Mar 6, 2005 | 03:08 PM
Dwight Schrute's Avatar
eg seats have got to be the worst designed seats ever. they are not very comfortable either. i would just get some ef si seats. them bishes are comfortable
Old Mar 7, 2005 | 08:53 AM
bigslimdog's Avatar
Default Re: EG Seats into an EF? (drewthomas14)
I appreciated the input and recommendations but this is what I have and what's available to me. I just want to know what I would need to do to get these to work in my car.
Old Mar 7, 2005 | 10:09 AM
Superhatch's Avatar
I had some del sol seats in one of my old Hatches. I used a thick steel plate as an extender to mount the front hole that didnt line up, and ended up drilling a seperate hole in the rear to get one of the rears to be lined up. I think I used a spacer to overcome the difference in height in the rear. It ended up being really solid, and I actually got rear-ended from behind at 35mph while I was at a stoplight, totaling the car, but my seat held fast. Youll have to do some work to get them to fit safely...but you can do it.
-Jake
Old Mar 7, 2005 | 01:22 PM
jdmitr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewthomas14 &raquo;</TD></TR><TR><TD CLASS="quote">eg seats have got to be the worst designed seats ever. they are not very comfortable either. i would just get some ef si seats. them bishes are comfortable</TD></TR></TABLE>
I would have to disagree. Ek seats are ****!!! I hate them! No support at all! At least EG seats have some support! IMO
I also put eg seats in my wifes EF years ago. I used some very thick and wide washers for the holes I had to drill for the back mounts (more surface area). They were a little high but leaps and bounds better than the ratty ef's!
Old Mar 8, 2005 | 07:19 AM
bigslimdog's Avatar
Default Re: EG Seats into an EF? (jdmitr)
bump
Old Mar 9, 2005 | 03:14 PM
bigslimdog's Avatar
bump!
Old Mar 12, 2005 | 08:48 AM
bigslimdog's Avatar
can anyone else help me out?
Old Mar 12, 2005 | 09:36 AM
ssl2k's Avatar
i have a delsol seat in my 88 crx,
front 2 botls and 1 rear match up, the 4th bolt...i just tacked it with the wire feed
Old Mar 15, 2005 | 07:34 AM
bigslimdog's Avatar
Default Re: (ssl2k)
bump
Old Mar 15, 2005 | 08:43 AM
IntegraXSi's Avatar
Default Re: (bigslimdog)
Friend of mine had EG seats in his EF.. DONT DO IT , They sat way to high I'm only 5'9" and My head was less then 2 inches from the Headliner I had to duck down to get out ...
Old Mar 15, 2005 | 09:13 AM
EFz6er's Avatar
Default Re: (IntegraXSi)
My hatch has Si seats...
Old Mar 15, 2005 | 04:24 PM
bigslimdog's Avatar
Default Re: (EFz6er)
Hmm...I think I'll just try to sell the EG seats and go with something else. Thanks for the input everyone.
joerox
Jan 31, 2010 08:03 PM
wernhersey
Jul 18, 2007 03:06 PM
str8drift
Nov 28, 2005 10:40 AM
Fabrik8
Nov 7, 2002 05:21 PM
Cereal_Killer
Apr 12, 2002 10:33 AM
