usdm f22b sohc vtec into 93 prelude Si
my friend's H23 has spun bearings so he is swapping in a F22b sohc vtec that he got for $450.
he got the motor, tranny, ecu, and a chopped up wiring harness. Can he use the axles from his H23? What about the wiring harness? what else will he need to complete the swap?
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dougs96SI »</TD></TR><TR><TD CLASS="quote">I thought that the F22b was a 2.2L DOHC non-vtec.
If it is an F22b then he can use his stock axles (from what I have heard).</TD></TR></TABLE>
usdm F22b = sohc vtec 135 hp
jdm F22b = dohc non-vtec 160 hp
do you know if the H23 axles will work with a USDM F22b tranny?
edit: should I post this in the hybrid forum?
Oh ok I got a little confused because your first post didnt mention USDM/JDM. My Fault. The Hybrid forum would probably have some useful information concerning this.
Yea, you would use H22/H23 axles.
I think the major problem is the distributor. Accord has an internal coil, Prelude has an external coil. Accord harness will fix that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Launchpad McQuack »</TD></TR><TR><TD CLASS="quote">my friend's H23 has spun bearings so he is swapping in a F22b sohc vtec that he got for $450.
thanks</TD></TR></TABLE>
from my knowledge, the difference would be if it ABS or non-ABS... so obviously, if the 'lude has ABS i would use ABS axles... there is also a difference if it is a MT or AT
IndecentXxXposur
May 22, 2009 01:00 PM
