92 eg hatch rear disc brake conversion questions
i have a 92 dx hatch and a 94 integra LS (R.I.P.) and i have done the front conversion on my hatch already
Im ready to do the rear disc conversion on monday
ive heard alot of different stories on how to do this conversion
i plane on taking the rear disc off the ls in one peace and puting them on the hatch i guess thats the easy part
<U></U>QUESTIONS
Can i keep the same brake lines under the car
Do i need to change the brake booster on eg to the ls one
Can i us the LS lines at firewall to connect the master cylinder
Do i have to put the ABS on the eg
IF YOU HAVE DONE THIS BEFORE PLEASE GIVE ME SOME TIPS ON HOW TO DO THIS CORRECTLY
<U></U>QUESTIONS
swapping the entire arm is easier than swapping just the hub, if you ask me.
you need the rear disc lines, not drum lines
I recommend you change to the larger booster
you'll need to use the civic's lines and adapt them
You will not be adding abs - you cant add abs without lots of work.
ovsrcivicek9
Mar 4, 2012 10:56 PM
saintg2005
Feb 24, 2008 11:35 PM
stickyfingers
Jun 30, 2005 09:22 PM
Del_Sol_s
Feb 3, 2005 01:30 PM
LudeHatchH22a
Nov 3, 2003 10:51 PM
