will 96 gsrOBD2 TB with TPS and MAP work on 94 OBD1 ls motor
and will it work correctly
I have been through 2 ls TBs with TPS reinstalled and niether worked right after a hundred adjustments and using voltmeter to test niether would go to 5.0 volts
I found a 96 gsr TB with original TPS will it work since its OBD2 and my Motor is OBD1
ya it does but mine is 4.87
its supposed 2b 5.0 with ignition in acc. position and throttle closed according to haynes manual and my TPS reads 9.6 -9.7 while adjusting it
Colorado_teggy
Feb 26, 2014 01:08 PM
97grnrs
Mar 20, 2006 08:48 AM
STPREZ
Mar 5, 2005 07:06 PM
