will 96 gsrOBD2 TB with TPS and MAP work on 94 OBD1 ls motor
and will it work correctly
I have been through 2 ls TBs with TPS reinstalled and niether worked right after a hundred adjustments and using voltmeter to test niether would go to 5.0 volts
I found a 96 gsr TB with original TPS will it work since its OBD2 and my Motor is OBD1
Colorado_teggy
Feb 26, 2014 01:08 PM
STPREZ
Mar 6, 2005 05:19 AM
