buying a eg w/ ls swap??
i am in the process of buying another eg, but this time it already has a b-series motor in it already. but i was wondering how do you tell if the swap is legit?? can i get it checked out somehow?? the swap is a 94 integra ls into a 92 civic si. any numbers i can run on the block??
if it's a usdm motor it should have it's vin plate right where u can see it. i THINK you can run the block numbers...not entirely sure...but once u find out what numbers u can run, just call up the chp and have them run a check for u.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prjctCIVIC »</TD></TR><TR><TD CLASS="quote">isnt only the obd2 motors the ones with the vin plates??</TD></TR></TABLE>
I believe so.
94-95 had no vin plates located on the motor or trans.
96+ had vin plates near the oil pan and on the front of the trans.
I believe so.
SluggishDA
Jul 28, 2009 07:18 AM
egturbo
24
Mar 17, 2003 02:48 PM
