Accord EX idling Jumping up and down help!
Old Mar 5, 2005 | 04:24 PM
DXK Eg's Avatar
Default Accord EX idling Jumping up and down help!
I have a 90 accord EX engine is F22A1, the engine idling up and down, bogging up and down right when you start the car, but when you drive it, it is fine and it doesn't bogg or idle anymore. It only idles when I start the car up in the morning..any help would be appreciated, ,I have put in new spark plugs and spark plug wire..what esle should i do or check for?
Old Mar 5, 2005 | 04:33 PM
hondadude's Avatar
Default Re: Accord EX idling Jumping up and down help! (dynasty-x-motorsport)
Coolant level full and block burped thru the 12mm bleed screw at the T-stat housing? The next thing would be to adjust the fast idle valve. The link below should help you.
http://members.troublecodes.ne...8.jpg
Remove the cover plate of the fast idle valve and turn the 'split screw' down a couple turns.
ben_tech
Oct 11, 2023 08:41 PM
caw
Nov 28, 2010 04:52 PM
brandonaccord
Jul 31, 2009 07:06 PM
tgkaotic
Aug 8, 2007 04:09 AM
7808
Sep 16, 2005 10:45 AM
