polyurathane bushings
Old Mar 5, 2005 | 02:58 PM
crxcrazysi's Avatar
Default polyurathane bushings
What are some common recomendations for using poly bushings ie.. Ok for everyday driver or just track. certain poly bushings i'd imagin would be good motor mount shift linkage etc.. just wanderin......
Old Mar 5, 2005 | 03:00 PM
krazie1's Avatar
BANNED
Default Re: polyurathane bushings (crxcrazysi)
track car bro
I love and can handle the ride quailty for daily useage but most peeps can't take the 6 or 4 puck unsprung clutches
I just different I guess
if u do get them u will feel everything on the road and plus launch better
Old Mar 5, 2005 | 04:01 PM
V8SHME8's Avatar
It is not a big deal if you lube them, the squeaking can be annoying. Either way, our cars are old and I would rather have a stiff ride than old cracked and broken rubber bushings.
Old Mar 5, 2005 | 04:03 PM
kulangot's Avatar
Default Re: polyurathane bushings (V8SHME8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by V8SHME8 &raquo;</TD></TR><TR><TD CLASS="quote">It is not a big deal if you lube them, the squeaking can be annoying. Either way, our cars are old and I would rather have a stiff ride than old cracked and broken rubber bushings. </TD></TR></TABLE>
Old Mar 5, 2005 | 06:02 PM
insomniac791's Avatar
i have the full set in my daily driver and I commute 100 mile per day. They are really not that bad. mine do not squeak at all. It rides like I have my 17" wheels on there again.
Later
Matt
Old Mar 6, 2005 | 05:44 AM
crxcrazysi's Avatar
Thanks for the replys!!! I have a total kit package but just not sure if i should use them. I put alarger diameter rear lower sway bar on my crx and that seems to be stiff enough with just rubbers so maybe i shouldn't use them cause i plan to upgrade suspension more with coils and struts.
Modified by crxcrazysi at 10:49 AM 3/6/2005
Old Mar 6, 2005 | 04:53 PM
NCchris's Avatar
Default Re: (crxcrazysi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxcrazysi &raquo;</TD></TR><TR><TD CLASS="quote"> i plan to upgrade suspension more with coils and struts.
Modified by crxcrazysi at 10:49 AM 3/6/2005</TD></TR></TABLE>
If you are upgrading your suspension, you'll like the poly bushings even more!
HTH
chris
PhatRoyale
Jul 5, 2008 09:48 PM
wicked2night
Dec 31, 2006 07:34 AM
92DAturboteg
Dec 22, 2006 05:42 AM
ludesrv
Jun 1, 2006 09:56 PM
TeaAddict
Dec 7, 2004 07:21 PM
