2001 gsr to 1994 gsr dashboard
Old Mar 5, 2005 | 02:36 PM
doggydog's Avatar
Default 2001 gsr to 1994 gsr dashboard
I want to put a 2001 gsr dashboard on my 94 gsr. No modifications, will it fit like stock? I will probably have to swap all the wiring from 94 to 2001 dash, correct? Any help wpould be appreciated. Thanks
Old Mar 5, 2005 | 02:42 PM
LSvtec03's Avatar
Default Re: 2001 gsr to 1994 gsr dashboard (doggydog)
use your old wiring. everything will bolt in perfectly.
Old Mar 5, 2005 | 04:00 PM
njandrewg's Avatar
Default Re: 2001 gsr to 1994 gsr dashboard (LSvtec03)
its just a dash board....it'll just bolt right in
Old Mar 5, 2005 | 04:56 PM
Cliffjumper2's Avatar
your main dash wire harness is not part of your dash board.....so when you remove the dash, you'll just have to unplug a few harness plugs that go to your radio/climate control/dimmer switch/cluster/srs/security system
the dash you're picking up should already have those wires/plugs, but if not, you'll have to use the plugs from your old dash.
otherwise it's a straight forward swap. I put a 99 gsr dash board into a 94 integra LS, and wrote it up here:
https://honda-tech.com/zerothread?id=954173
Old Mar 5, 2005 | 05:32 PM
doggydog's Avatar
Default Re: 2001 gsr to 1994 gsr dashboard (Cliffjumper2)
Hey Cliff, thats one great write up. I will sure use it on my car. Thanks for your time.
Old Mar 5, 2005 | 05:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doggydog &raquo;</TD></TR><TR><TD CLASS="quote">Hey Cliff, thats one great write up. I will sure use it on my car. Thanks for your time.</TD></TR></TABLE>
no problem.......hope it goes smoothly for you
SlowB16
Feb 9, 2013 02:08 AM
marcusgnf
Jan 18, 2006 04:43 PM
sq_lover
Feb 11, 2005 11:59 AM
evad
Dec 6, 2004 01:47 PM
krookedeg6
Jun 7, 2003 04:37 AM
