clutches
*Searched*
Are 91 dx and si clutches interchangeable? also,when replacing a clutch, what componets should be replaced? If anyone has links to some reading on clutches. it would be appreciated.
Thanks
Modified by silver hatch at 7:05 AM 3/6/2005
Thanks
Im almost 100% sure they are the same
You should repleace pressure plate, clutch disc, throw out bearing, and pilot bearing. Also it would be a good idea to get the flywheel resurfaced
