simple pr4 ecu question
Old Mar 5, 2005 | 01:43 PM
model x's Avatar
Default simple pr4 ecu question
do all the pr4 ecu's have a 16 pin connector?
The one in my car does but the one in the manual I have has a 22 pin connector and its named 'D'
Old Mar 5, 2005 | 05:06 PM
Cliffjumper2's Avatar
Default Re: simple pr4 ecu question (model x)
not sure of the pin count......
but I do know that there are two pr4 ecus; one was for the 90-91 integra and the other for the 92-93 integra. The connectors are different between the two.
I found this out when I picked up a pr4 ecu to run on a 90 crx that I had with a b18a swap (it was running on a pm6 ecu )
anyway, when I try to plug the ecu in, it doesn't fit..........found out it was because it was for an obdI 92-93 integra.
got a hold of a obo0 pr4 ecu (90-91 integra) and it pluged right in.
Old Mar 5, 2005 | 08:26 PM
model x's Avatar
Default Re: simple pr4 ecu question (Cliffjumper2)
I think the manual I have only shows the pin out for the 92-93, and that's why the colors don't match up.
anyone have any pin assignments for the 90-91 pr4 ecu?
Old Mar 6, 2005 | 02:43 PM
model x's Avatar
anyone have any info on the plugs?
Old Mar 8, 2005 | 02:40 PM
model x's Avatar
does anyone know the color codes for the c connector on the pr4?
Old Mar 8, 2005 | 03:13 PM
3.504's Avatar
be prepared to be hooked up.
hopefully you know how to read some simple wiring diagrams
Old Mar 9, 2005 | 01:45 PM
model x's Avatar
Default Re: simple pr4 ecu question (3.504)
now that is a beautiful thing.
Thankx dude
ObeyDB8
Apr 4, 2011 09:16 AM
turbohf
Oct 14, 2003 06:41 AM
