how to adjust clutch pedal, and also some days car wont start
first off how do you adjust the clutch pedal, its so high right now that it higher then like my brake pedal. and also some days the car wont start, its as if the clutch isnt pushed in all the way.like it'd be all the way to the floor, and nothing would happen, but then if i like push hard on it while its already on the floor it starts. (as if moving it like a centimeter)Other days it just doesnt start at all. Any idea's.thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matto2413 »</TD></TR><TR><TD CLASS="quote">first off how do you adjust the clutch pedal, its so high right now that it higher then like my brake pedal. and also some days the car wont start, its as if the clutch isnt pushed in all the way.like it'd be all the way to the floor, and nothing would happen, but then if i like push hard on it while its already on the floor it starts. (as if moving it like a centimeter)Other days it just doesnt start at all. Any idea's.thanx</TD></TR></TABLE>
sounds like the clutch interlock switch is not touching the pedal when you press the pedal in completely. That's what causing the hard to start issue.
For adjusting the clutch pedal, there's a push rod directly in front of the pedal. loosen the locknut and using a small ruler adjust the pedal to 15-20 mm(.059-0.79 in) that's it. OH BTW tighten the locknut which is common sense.
vtec25
34
Oct 16, 2005 06:44 PM
1999all_motoR_teg
Nov 16, 2004 10:43 AM
