Walbro 255 Fuel Pressure Question????
i think it will because of the volume of fuel that is flowing the stock one probably won't be able to handle it mabe you should get a 190 instead of a 255
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrsp33d »</TD></TR><TR><TD CLASS="quote">Will a Walbro 255 raise fuel pressure with a stock FPR? I heard it raises it about 8psi.
I dont understand why? Can someone please explain if it is true.</TD></TR></TABLE>
Yes it will. 46 psi before the install, 52 psi after the install.
You're supplying more fuel to the rail. As a result more fuel will pass through the return line. The stock fuel return orifice is sized for a 160 lph (i think) pump. Now that you're using a 255 the orifice is too small. The stock fpr becomes a restiction to your fuel system and pressure increases.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude »</TD></TR><TR><TD CLASS="quote">just get one to be safe, i've seen it both ways to where it doesn't increase fuel pressure and it doesn't increase it</TD></TR></TABLE>
hmm thats weird.
hmm thats weird.
Propulsion
Nov 24, 2003 09:38 AM
