which cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CIVICGEN2 »</TD></TR><TR><TD CLASS="quote">which cams shafts u recommoned on a itr buddy clubs spec 3 or 4 or skunks 2 stage 2</TD></TR></TABLE>
you got to be a little more specific nowadays when asking a ? like that in a this forum. Try listing your current setup and your goals., ie mods,management and if this car is a DD, strip, or a autox. hope this helps.
It also depends on how you want your car to feel. If you want something with more area under the curve that starts to pull right when you drop the hammer at 3000 rpms, then the BC3's are the way to go. Vtec is still imressive in the BC3 as well, but since the primary lobes are beefed up, there is not as much of a difference once the crossover occurs. If you prefer that kick in the pants when vtec kicks in and are willing to sacrifice some torque to get that loud vtec crossover, the S2s2 are the cams for you. If you like the idea of the S2S2, also consider the Blox B. If you like the idea of the BC3, also consider Toda B.
cause this is my setup
skunk 2 stage 1 cams and shafts
skunk values and spring and retiners
r/c 310 injectors
aem fuel rail
aem intake
jdm itr 4-1 headers
stock pipe (thining about going 2.5)
act pressure plate & light flywheel
six puck clutch
hondata (but it's acting up cause of setup)
r/c 310 injectors
aem fuel rail
aem intake
jdm itr 4-1 headers
six puck clutch
Kiniku Chunks!!!
Feb 6, 2007 07:30 PM
k20zno2
Dec 9, 2006 11:09 PM
thumper77fox
Apr 6, 2006 09:31 AM
