Question concerning small bandsaws???
Old Mar 5, 2005 | 08:14 AM
fastcivicboy's Avatar
Default Question concerning small bandsaws???
I was wondering how yall people like your small bandsaws? I know Jet makes one but its only 1/2 hp and the miter guage for the angles suck on it. A bolt actually blocks it from being able to move and be adjusted for angles. I picked up the 1 hp from harbor freight but the blade keeps popping off. anyone have this trouble. It didnt cut to well either. Im wondering if it would be better if I got a better blade. I dont know but I need to fix this blade popping off problem. Anyone else experience it? Anyone know a good bandsaw that will cut sch. 10 well and has a pretty reasonable price? -Nick
Old Mar 5, 2005 | 08:40 AM
Engloid's Avatar
OG Fabricator
Default Re: Question concerning small bandsaws??? (fastcivicboy)
Are you tightening the blade too much?
If it's under warranty, take it back.
Old Mar 5, 2005 | 08:44 AM
B18C1CYA's Avatar
the blade might not be tracking right or is to tight or to loose , you can adjust the tracking at the top wheel , look at the manual it should tell you how to do it , bandsaws are kinda funny at first to figure out how they like to be set up and to work problem free , but once you get it there should be no problems , also dont think it is going to fly right through stainless , that stuff is hard **** to cut so it takes longer .,
Old Mar 5, 2005 | 09:08 AM
Bailhatch's Avatar
Default Re: Question concerning small bandsaws??? (B18C1CYA)
ya the tracking might be it or maybe the guides are too far down? which wheel does it come off of. if its the drive wheel then the rear guide may be too low. Im sure you can get it working fine
Old Mar 5, 2005 | 09:11 AM
was the guides. Damn yall people are smart and fast. thanks for the quick replys, I really do appreciate it. -Nick
delsoldrew
Acura TL, RL & ZDX
Apr 16, 2006 06:32 PM
koolmoedee5
Welding / Fabrication
Dec 18, 2004 08:38 PM
LillDragun
Audio / Security / Video
Aug 23, 2004 08:24 PM
youngkow
Oct 15, 2002 06:28 PM
