Suspension & Brakes Theory, alignment, spring rates....
Tie Rod help
Old Mar 5, 2005 | 05:59 AM
weraider30's Avatar
Default Tie Rod help
i am putting the 10mm bolt back on my tie rod and when i get it to a certain point it caused the tie rod end to spin with the bolt. is there any way i can stop the spin so i can get the nut on?
Old Mar 5, 2005 | 06:54 AM
weraider30's Avatar
Default Re: Tie Rod help (weraider30)
help please
Old Mar 5, 2005 | 07:17 AM
fireant's Avatar
which car is it on? Is it the outer tie rod end or the inner?
Old Mar 5, 2005 | 07:26 AM
weraider30's Avatar
Default Re: Tie Rod help (fireant)
here is a pic
Old Mar 5, 2005 | 08:31 AM
Jamez's Avatar
That's your tip for changing them. Good ball-joints aren't supposed to turn in their housing. If your cheap and think you can still pull a few miles off them then an impact usually gets the nut in there.
Old Mar 5, 2005 | 08:32 AM
CerealWars's Avatar
Your talking about the end that attaches to the steering knuckle right? If so just get some force on it. Get a clamp and try to tighten it down and that should stop it from spinning. You can also use this method on upper and lower ball joints.
Old Mar 5, 2005 | 08:43 AM
weraider30's Avatar
Default Re: Tie Rod help (CerealWars)
i tried to impact it, clamp it, and nothing seems to work, i guess i need to order a new rod end. can any of you find it on here: http://www.hondaautomotiveparts.com
i can't find it on any of the components, i know its part of the ps system, but can't find it
Old Mar 5, 2005 | 09:22 AM
CerealWars's Avatar
Number 17 and 20. If its on the 92 Si. http://www.slhondaparts.com/br...=true I also perfer this place. And why not just head up to Autozone, Checker or your local Honda dealer if you need it now.
Old Mar 7, 2005 | 10:27 AM
weraider30's Avatar
had to break down and buy a new one, but thanks for the help
Smash03
Dec 11, 2007 11:01 AM
b0yg0tskills
Honda Civic (2001 - 2005)
Apr 13, 2007 06:38 AM
atg1290
Suspension & Brakes
Sep 24, 2006 02:47 PM
atg1290
Sep 3, 2006 03:55 PM
arcticblursx
Mar 29, 2003 01:00 AM
