honda crx dx distributor wiring
Old Mar 5, 2005 | 05:03 AM
TYPErCRX's Avatar
Default honda crx dx distributor wiring
i am dropping a ek type r motor into my honda crx DX and im looking for a wiring diagram with the pins numbers and placement for the wires and all for the b16b distributor. i believe my b16 distributor has 7 wires mean while the dx only had i believe 5 please help thanks
Modified by TYPErCRX at 8:01 AM 3/5/2005
Old Mar 5, 2005 | 08:25 AM
dr_latino999's Avatar
Default Re: honda crx dx distributor wiring (TYPErCRX)
Um...Ok, here is the amount of wiring you will have to do to make this work. Stop me if you get lost -
1) MPFI Wiring - Wiring up your chassis to go from two injectors to four
2) OBD-0 to OBD-1/OBD-2 - Depends on which ECU you are running the motor, you will either need to convert to OBD-1 or 2.
Old Mar 5, 2005 | 02:29 PM
TYPErCRX's Avatar
Default Re: honda crx dx distributor wiring (dr_latino999)
actually i found out where all the wires go but i cant find out the yel/grn wire if anyone knows where is goes great i think it would go with b15 or b17 tho let me know what u guys think thanks
Modified by TYPErCRX at 4:40 PM 3/5/2005
Old Mar 5, 2005 | 04:33 PM
bob06's Avatar
I had to rewire mine for my b16 too. Just open up the old distributor and the new one and take the coils our... trace the wires on both distributors and pin the new onw up like the old on and then run the 2 extra wires, both crank angle sensors, to C1 and C2. Leave them unsoldered on one end in case you have them backwards. You will know cause you will get a code and the car will run bad. To get the pins out of the plugs just use a pair of needle nose pliers and pull up on the pin from the inside and then push it out and it should just pop right out.
OhMy-EK9
Apr 24, 2012 09:56 PM
98AccordEX
Sep 4, 2003 10:34 AM
