clutch and flywheel install
Old Jan 21, 2002 | 07:15 PM
iwhichisme's Avatar
Default clutch and flywheel install
I have 3 questions here. One is i have a j1 tranny, and want to know what is the best clutch to go wiht; meaning what year ls should i get one for. Is the flywheel for any b16a able to fit the 1st gen. And last are there any speacial intructions to follow when installing a clutch and flywheel. Any help is help
thanxx
Old Jan 21, 2002 | 09:10 PM
AfEn808's Avatar
New User
Default Re: clutch and flywheel install (iwhichisme)
I would get a ACT clutch there good for the money usually about 300-350. Im pretty sure a flywheel for a b16 will fit a b16 also theres no special instructions to installing a clutch.
Old Jan 21, 2002 | 11:10 PM
samiam's Avatar
get a clutch setup for 90-91 teg. Any b series flywheel should work fine.
Old Jan 22, 2002 | 06:57 AM
1stGenCRXer's Avatar
Default Re: clutch and flywheel install (AfEn808)
That's *almost* true. You put less stress on the friction disk during install if you tighten down the pressure plate bolts evenly, making sure the alignment tool slides in and out smoothly the entire time, never binding. Once all the bolts are touching with the pressure plate firmly against the flywheel, then you can continue with final torque. The friction disk will be in perfect alignment, making tranny installation super smooth, and the friction disk be less likely to have suffered any un-due/un-even stress which could cause premature disk failure.
DFW
Feb 22, 2007 04:05 PM
nijia555
Aug 22, 2006 02:06 PM
AndyD
Jan 16, 2006 12:58 PM
gotnothing
Dec 9, 2002 02:43 PM
thecorey
Sep 27, 2002 03:03 PM
