:::G-C&koni yellow, What rest of parts do i need?:::
iam plan to get koni yellow and Ground Control..i heard that i have to use few parts from stock shock..what are they? and can i get after market ones? no from stock suspention.
thanks
thanks
You'll need the
- bump stops (some new ones would be good, though)
- the brake line brackets (some people manage without these
by zip-tying a zip tie to a zip tie, just done let the brake lines rub on the damper)
- upper strut "hat" assembly with its various bushings and washers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris DC2 »</TD></TR><TR><TD CLASS="quote">i heard that koni comes with bump stop.is that right???</TD></TR></TABLE>
No. You have to reuse your stock bump stop if you're going to reuse your stock upper mounts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">and are ground control top hat is only for racing? not for street??</TD></TR></TABLE>
There are two versions of the GC upper mounts - the "race" mounts, and the "extended travel" mounts. If you want to put these on a street car, you'll want the extended travel mounts; they add about 3/4" of shock travel and come with a new bump stop.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
There are two versions of the GC upper mounts - the "race" mounts, and the "extended travel" mounts. If you want to put these on a street car, you'll want the extended travel mounts; they add about 3/4" of shock travel and come with a new bump stop.</TD></TR></TABLE>
oh thank you..so all i need is G-C&koni&extended tracel top hat...no stock parts will used on that right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris DC2 »</TD></TR><TR><TD CLASS="quote">oh thank you..so all i need is G-C&koni&extended tracel top hat...no stock parts will used on that right?</TD></TR></TABLE>
Shouldn't be. The upper mount cups, bushings, and bump stops were the only things we needed to salvage from the stock coilover assemblies for my GC coilovers. I've been looking into getting a pair of the GC extended travel upper mounts for the front, since more travel is a good thing.
ProPartsUSA
Jul 17, 2013 03:18 PM
