i have a rsx engine what will i need to do tpo put it in a crx
Old Mar 4, 2005 | 11:45 PM
flatblk's Avatar
Default i have a rsx engine what will i need to do tpo put it in a crx
i have a rsx engine what will i need to do tpo put it in a crx everything?
Old Mar 5, 2005 | 01:05 AM
Cornwhiskey's Avatar
Default Re: i have a rsx engine what will i need to do tpo put it in a crx (flatblk)
search
Old Mar 5, 2005 | 01:09 AM
limpy's Avatar
Default Re: i have a rsx engine what will i need to do tpo put it in a crx (sparvar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sparvar &raquo;</TD></TR><TR><TD CLASS="quote">search</TD></TR></TABLE>
i like your sig.... so verry true
Old Mar 5, 2005 | 04:41 AM
1RMDave's Avatar
Default Re: i have a rsx engine what will i need to do tpo put it in a crx (limpy)
go to http://www.hasport.com They have mounts/wiring/axles. It is pricey but well worth it if you're not capable of doing any of that stuff.
Old Mar 5, 2005 | 08:06 AM
dr_latino999's Avatar
Open your eyes, found at the bottom of the page - How To Swap a K-Series Motor For Dummies
Old Mar 5, 2005 | 02:18 PM
crxtreme89h's Avatar
Default Re: i have a rsx engine what will i need to do tpo put it in a crx (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Open your eyes, found at the bottom of the page - How To Swap a K-Series Motor For Dummies</TD></TR></TABLE>
Oh! There it is!
Old Mar 5, 2005 | 10:03 PM
flatblk's Avatar
do i need axles too or everything bolt on
Old Mar 5, 2005 | 10:06 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (flatblk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flatblk &raquo;</TD></TR><TR><TD CLASS="quote">do i need axles too or everything bolt on</TD></TR></TABLE>
yeah it will bolt right in you can even use your 0bd0 harness plug and play swap should take 2 hours max
on the hasport site it lists everything that you need.
Old Mar 6, 2005 | 12:45 AM
FalkenSiR's Avatar
Default Re: (HatchBox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">
yeah it will bolt right in you can even use your 0bd0 harness plug and play swap should take 2 hours max </TD></TR></TABLE>
Pretty much. Oh, and shift linkages are plug and play, i heard.
Old Mar 6, 2005 | 07:35 AM
tolnep's Avatar
Well.. not what I would call swap for dummies... if you search the net for b-series swaps there are numerous step by step instructions with people that have done it before with pictures, parts lists.. on and on.. With this new kit, there are no complete instructions, step by step, parts.. yet. For instance, no mention ne way or the other about AC, no steps for setting up shift linkage, just some basic info about what might work. I have a fairly complete set of tools including air tools, engine hoists and stands. I have no doubt I could do a B series swap to a CRX, but I would not attempt a k series yet until the parts and instructions are complete. The idea of an RSX-s with a 6 speed in my CRX is worth waiting for...
Old Mar 6, 2005 | 11:57 AM
Default Re: i have a rsx engine what will i need to do tpo put it in a crx (tolnep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tolnep &raquo;</TD></TR><TR><TD CLASS="quote">Well.. not what I would call swap for dummies... if you search the net for b-series swaps there are numerous step by step instructions with people that have done it before with pictures, parts lists.. on and on.. With this new kit, there are no complete instructions, step by step, parts.. yet. For instance, no mention ne way or the other about AC, no steps for setting up shift linkage, just some basic info about what might work. I have a fairly complete set of tools including air tools, engine hoists and stands. I have no doubt I could do a B series swap to a CRX, but I would not attempt a k series yet until the parts and instructions are complete. The idea of an RSX-s with a 6 speed in my CRX is worth waiting for...</TD></TR></TABLE>
If you read the attached .pdf to the link I provided it walks you through it. True, it doesn't hold your hand with a lot of pictures (who I must say like pictures) but it tells you how it can be done. Now with AC on K-Series swap, most people will not be running AC with this swap until some serious custom work is done to the lines and we can not forget the hood clearance issues.
Old Mar 6, 2005 | 12:43 PM
.Noah Fecks's Avatar
1500 just to put it in? **** that doesnt include how your gonna shift it, or the ******* motor itself. god damnit. built b series is the way to go.
Old Mar 6, 2005 | 12:44 PM
doublethink's Avatar
dude, if you spend 2 grand in parts from hasport and you run into a snag, you can call them they will help you. they stand behind their products.
or you can always come on here and ask, or k20a.org... pacman had the swap even when there was no mounts to buy.
anyways, im looking to do the same swap this summer, i need to save up another 3 grand and i should have enough for a usdm k series, 500$ a month put away.
good luck!
Old Mar 6, 2005 | 03:39 PM
tolnep's Avatar
If you read the attached .pdf to the link I provided it walks you through it. True, it doesn't hold your hand with a lot of pictures (who I must say like pictures) but it tells you how it can be done. Now with AC on K-Series swap, most people will not be running AC with this swap until some serious custom work is done to the lines and we can not forget the hood clearance issues.</TD></TR></TABLE>
Ah.. OK. this is basically from that instruction sheet.. attach the cables to the RSX tranny.... run it to the shifter and attach it somehow? How. Other forum info suggests a custom box for the shifter? under the floorboard or just mounting it on the floorboard.. For me this aint enough info.
But I am sure the details will eventually come out as those who like to be on the bleeding edge shed some blood...
FROM THE PDF.....
Install RSX shifter cables on the transmission. Route the shifter cables into the Civics’ cabin by cutting a small hole in the floor in front of the old shifter location or low on the firewall. Check clearances with items like sway bars and catalytic converters to choose the best path.
Old Mar 6, 2005 | 09:22 PM
it says cut a hole in the firewall to accomodate it.
it must be at a different angle or perhpas shorter in overall length and therefore cannot go totally under the car as the stock linkage did.
k20z
Nov 18, 2007 07:49 PM
UCLA.lion
42
Jul 18, 2006 03:08 AM
IBriaIN
Mar 2, 2006 11:29 AM
HONDAzZz
16
Jan 27, 2004 06:22 AM
04-K20A2
Jan 19, 2004 08:47 PM
