crx gtech time really slow?
Old Mar 4, 2005 | 11:19 PM
asilaydying1984's Avatar
Default crx gtech time really slow?
r gtechs accurate, becasue i have a 91crxhf with a b16 with ctr cams skunk2 im, ported throttlbody 4-1 header with 2.5 inch collector and a 2.5 inch catback, lightened flywheel, no ac, konig 15 inch heliums with bfg drag radials, and it is saying i am running a 15.3, i dont see how that is possible, i know i can improve on my launches but i was expecting like a 14.3 i wonder if my motor is just a piece of crap or if it is all just my launches
Old Mar 4, 2005 | 11:40 PM
hebelect's Avatar
Default Re: crx gtech time really slow? (asilaydying1984)
gtech = junk
15.3 doesnt sound right at all
Old Mar 5, 2005 | 05:36 AM
Sikocivic's Avatar
Default Re: crx gtech time really slow? (hebelect)
You need to imput the correct weight for your car. Most people say the car is lighter than it really is and they run real fast times. Maybe you are telling it that your car weighs more than it really does. Most of the time G-techs are very close to what you will really run.
Old Mar 5, 2005 | 06:27 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: crx gtech time really slow? (Sikocivic)
I'm just curious, but why on earth would you need to tell it how much your car weighs??? It just measures acceleration force, right? And that shouldn't change whether it's a 2000lb car or a 4000lb car. Did I miss something here?
confused
Old Mar 5, 2005 | 06:38 AM
fireant's Avatar
Default Re: crx gtech time really slow? (tjbizzo)
The secret is to measure your times going downhill, not uphill.
Old Mar 5, 2005 | 06:42 AM
Iceycrx's Avatar
Default Re: crx gtech time really slow? (fireant)
if you get tons of wheel hop your times are screwed. Make sure you have it setup correctly on your window
Old Mar 5, 2005 | 06:45 AM
DJ_SaNdOz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tjbizzo &raquo;</TD></TR><TR><TD CLASS="quote">I'm just curious, but why on earth would you need to tell it how much your car weighs??? It just measures acceleration force, right? And that shouldn't change whether it's a 2000lb car or a 4000lb car. Did I miss something here?
confused </TD></TR></TABLE>
It's a mathemtical equation that tries to take weight, wind resistance, etc into consideration....
Old Mar 5, 2005 | 07:05 AM
TrueNorthStar's Avatar
Default Re: crx gtech time really slow? (DJ_SaNdOz)
I do belive that it only uses weight for it HP calculations. As for measurings your 1/4mi times all. it would need is acceleration force and time.
15.3 isnt bad for the street, you have to remember that the street isnt covered in VHT and the asphalt doesn't have rubber ebeded in every lil crack from a few thousand burnouts like a track. I can launch my car @ 5.5-6k on a track with lil to no wheel spin while on the street I can only launch at 2.5-3k on the street.
Also, g-tech's are very sensitive to how level the road is and bad wheel hop.
Old Mar 5, 2005 | 07:43 AM
well i was expecting it to at least read in the 14s,not a 15.3.
Old Mar 5, 2005 | 07:52 AM
naptownrex's Avatar
Default Re: (asilaydying1984)
you have to make sure that ur running your car on a perfectly level road- I ran my car with stock motor on a flat road, and got like a 16.3, but when i ran it up hill, i ran like a 15.9. so, the angle of the terrain matters a great deal.
b16_madman's Avatar
well if you are dead correct on your weight, and all that they are pretty darn accurate.
example) recently dyno'ed a e26m3 on a near new dynoyet, then about i dunno a month later or so we used a gtech pro to dyno it, same mods....... 5hp difference
that's pretty darn good if you ask me, just gotta get the weight right.
Old Mar 5, 2005 | 08:18 AM
tjbizzo's Avatar
Default Re: (B16_madman)
Just to make it perfectly clear, the vehicle weight that you enter into the unit will only effect the hp calculation, it will NOT effect the ET.
Old Mar 5, 2005 | 08:22 AM
hebelect's Avatar
Default Re: (tjbizzo)
my 90 si a6 power with intake manfold, I/H/E, wires ran a 15.5
Old Mar 5, 2005 | 09:22 AM
DJ_SaNdOz's Avatar
Default Re: (hebelect)
I've had a Gtech for like 3 weeks now, but I haven't used it yet. I'll try it out today I guess. I got it from ebay forlike $35 or $40 shipped, brand new. It's the original model though, not the new pretty one.
Old Mar 5, 2005 | 09:49 AM
mengo_charged's Avatar
Default Re: (DJ_SaNdOz)
How about go to the drag strip?
Old Mar 6, 2005 | 11:03 PM
i moved the gtech to a lower part of the window becaus ei had it high up on the window, and i ran a 14.49, and that sounds more like it. kind of relieves me
04stealthWRX
Jul 23, 2007 06:47 PM
jermjerm2
14
Jul 31, 2004 03:44 AM
dc2_and_ef
Jan 3, 2004 12:17 PM
d16a6
12
Oct 5, 2003 06:22 PM
