Oh yes Are short shifters nessely bad for ur tranny ???? please help .... also ...Need a b16 swap t
Old Mar 4, 2005 | 08:32 PM
TheJunBuilt's Avatar
Default Oh yes Are short shifters nessely bad for ur tranny ???? please help .... also ...Need a b16 swap t
need a b16 manual swap to a ef how to do ??? also are short shifters bad on trannys ..please help?
Old Mar 4, 2005 | 10:02 PM
Default Re: Oh yes Are short shifters nessely bad for ur tranny ???? please help .... also ...Need a b16 sw
bump...please
Old Mar 4, 2005 | 10:08 PM
Synth124's Avatar
The B16 swap has been done tons of times. Search around and read, this site has plenty information on how to do it.
Old Mar 4, 2005 | 10:17 PM
thatbluecrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirJdm &raquo;</TD></TR><TR><TD CLASS="quote">also are short shifters bad on trannys ..please help?</TD></TR></TABLE>bad drivers create bad trannys
Old Mar 4, 2005 | 10:18 PM
hahagasdcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thatbluecrx &raquo;</TD></TR><TR><TD CLASS="quote">bad drivers create bad trannys</TD></TR></TABLE>
Well said.
Old Mar 4, 2005 | 11:41 PM
hebelect's Avatar
short shifters are bad for your trannys syncros...
Old Mar 5, 2005 | 01:13 AM
limpy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hebelect &raquo;</TD></TR><TR><TD CLASS="quote">short shifters are bad for your trannys syncros... </TD></TR></TABLE>
not as long as your not jamming the gears, if it shifts fine then you are not hurting anything.
Old Mar 5, 2005 | 01:28 AM
CRXDrew's Avatar
could not have said it any better. x10
Old Mar 5, 2005 | 03:37 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by limpy &raquo;</TD></TR><TR><TD CLASS="quote">
not as long as your not jamming the gears, if it shifts fine then you are not hurting anything.</TD></TR></TABLE>
The problem with short shifters is that they force faster shifts than would otherwise occur (with a given speed at which the lever is moved, that is). This is what is bad for synchros. So unless you actually slow down lever motion after adding a short shifter, you ARE wearing out your synchros more quickly.
Extreez
Sep 24, 2006 07:49 AM
egryda
Honda Motorcycles
Mar 12, 2005 09:25 AM
djblackcell
Jun 1, 2004 05:02 PM
al3e
Jul 31, 2003 12:11 PM
1320sLEEper
May 4, 2003 10:56 PM
