Whining noise when shifting 2nd, 3rd, 4th or just accelerating????
Old Mar 4, 2005 | 03:47 PM
95greenteg's Avatar
Default Whistling noise when shifting 2nd, 3rd, 4th or just accelerating????
I've had this problem for about 5 months now...It is MAD annoying! Every time I accelerate my car makes this whistling noise when shifting from 2 to 3, 3 to 4, 4 to 5. Sometimes it just does it when I accelerate on 4th or 5th without shifting. I searched and alot of you guys have had different whining noises so I wanted to be exact with mine...Anyone out there ever had this prob?? I don't want my tranny giving out on me but I'm not sure if it is my tranny....What do you guys suggest??
Modified by 95greenteg at 5:18 PM 3/5/2005
Old Mar 4, 2005 | 10:01 PM
95greenteg's Avatar
Default Re: Whining noise when shifting 2nd, 3rd, 4th or just accelerating???? (95greenteg)
any help guys??
Old Mar 4, 2005 | 10:06 PM
PrettyLude's Avatar
your gonna have to isolate the noise and see where its coming from. it could be coming from many places, us giving guesses would be stabbing in the dark
Old Mar 4, 2005 | 10:42 PM
95greenteg's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">your gonna have to isolate the noise and see where its coming from. it could be coming from many places, us giving guesses would be stabbing in the dark</TD></TR></TABLE>
Okay, my bad...I forgot to mention that. It sounds like it's coming from near the alternator...I also noticed it only happens around 2k rpm...
Modified by 95greenteg at 4:58 PM 3/5/2005
Old Mar 6, 2005 | 12:40 PM
j87w's Avatar
Default Re: (95greenteg)
I have the exact same problem. I own a 95 LS. I replaced the Alternator and that didnt fix it. My car also makes a humming noise at idle or if I driving it for a while. Some say it almost sounds like a turbo spooling sound.
Old Mar 6, 2005 | 12:52 PM
95greenteg's Avatar
Default Re: (j87w)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j87w &raquo;</TD></TR><TR><TD CLASS="quote">I have the exact same problem. I own a 95 LS. I replaced the Alternator and that didnt fix it. My car also makes a humming noise at idle or if I driving it for a while. Some say it almost sounds like a turbo spooling sound. </TD></TR></TABLE>
Okay, good thing you posted that you replaced the alternator because that is what I thought my problem was coming from...I think it might be my intake though because a couple guys over Team-Integra.com suggested the intake. I have a cheapo replacement filter in the stock box...I'll be buying a K&N drop in soon so we'll see what happens...Mess with your intake and let me know what you get
Old Mar 6, 2005 | 01:26 PM
j87w's Avatar
I have an AEM intake. I sounds like its coming from under the IM and near the alternator. I still cant figure out what it could be. Someone said it maybe that I need to replace my IM gasket.
Old Mar 6, 2005 | 09:46 PM
95greenteg's Avatar
Default Re: (j87w)
What is the IM???
Old Mar 6, 2005 | 10:47 PM
extra cam needed's Avatar
From: americas finest, calee fourn ya, united states
IM- INtake Manifold - maybe they think it's leaking but you'll feel more things wrong with the car if that's leaking. check your belts around that area especially if you think it's not the altenator sometimes it can be hard to pinpoint sounds in a running engine.
Old Mar 7, 2005 | 01:20 AM
95civickid's Avatar
Default Re: (extra cam needed)
sounds like you guys have an exhaust leak.
Old Mar 7, 2005 | 07:18 AM
j87w's Avatar
Default Re: (95civickid)
No its def not. It makes a humming noise in my car sometimes when it idles. Then when I take off it sounds like a turbo is spooling. Then sometimes when I shift you can hear it "squel". The alternator did have bad bearings so the squeling when shifting when away sorta.
Old Mar 7, 2005 | 06:29 PM
95greenteg's Avatar
i also thought it was this because it happened right after I threw in a brand new cat...I will start troubleshooting as soon as it starts getting nice out here...It's cold and thare's still plenty of snow on the ground
Old Mar 7, 2005 | 06:31 PM
95greenteg's Avatar
Default Re: (j87w)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j87w &raquo;</TD></TR><TR><TD CLASS="quote">I have an AEM intake. I sounds like its coming from under the IM and near the alternator. I still cant figure out what it could be. Someone said it maybe that I need to replace my IM gasket. </TD></TR></TABLE>
I definitely don't think it's the intake manifold...The bolts on mine are like rusted on there for life...
Old Mar 9, 2005 | 09:25 PM
j87w's Avatar
One of my friends say to fill up my powersteering system (its already full), and then he told me to put belt dressing on all the belts. Anyone got any other ideas?
Old Mar 10, 2005 | 06:33 AM
AFTERZERO's Avatar
Default Re: (j87w)
Press your cluth down while on Idle, then listen to see if the noise sounds lowers... it might be coming from a bad bearing inside the trans.
Old Mar 10, 2005 | 06:55 AM
95greenteg's Avatar
Default Re: (AFTERZERO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AFTERZERO &raquo;</TD></TR><TR><TD CLASS="quote">Press your cluth down while on Idle, then listen to see if the noise sounds lowers... it might be coming from a bad bearing inside the trans.</TD></TR></TABLE>
The noise is not there while on idle though...Only when accelerating.
Old Mar 10, 2005 | 07:17 AM
AFTERZERO's Avatar
Is your trans fluid filled to the top?
Old Mar 10, 2005 | 03:43 PM
95greenteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AFTERZERO &raquo;</TD></TR><TR><TD CLASS="quote">Is your trans fluid filled to the top?</TD></TR></TABLE>
I don't know but I got it changed about 4 months ago...I will be checking for that soon though...
Old Mar 10, 2005 | 06:02 PM
j87w's Avatar
I think Its either the AC compressor on mine. I sat there and narrowed it all down while listening to it.
De_tour
12
Aug 3, 2007 05:55 PM
islander11
Aug 23, 2006 02:10 PM
hybrider
Nov 23, 2005 09:25 AM
95greenteg
Mar 5, 2005 02:06 PM
