How do you get the speedomter Gear out?
Old Mar 4, 2005 | 03:45 PM
EJ2-Fluffy's Avatar
Default How do you get the speedomter Gear out?
Hey, I have a 1989 CRX SI (D16A6) Manual Transmission. I found out my speedometer cable won't go in due to something being broken within the shaft itself.
The blue is where the speedometer cable goes in. The pink is the assembly of it.
Is there an easy way to remove the speedometer gear
Jon
Old Mar 4, 2005 | 03:54 PM
kulangot's Avatar
Default Re: How do you get the speedomter Gear out? (CRX-Fluffy)
vice grips....thats how i did mine...
Old Mar 4, 2005 | 04:00 PM
EJ2-Fluffy's Avatar
Default Re: How do you get the speedomter Gear out? (sirq2u)
Mines stuck =\ It feels like it was pressed in.
Old Mar 4, 2005 | 04:04 PM
kulangot's Avatar
did you try moving it back and forth?
Old Mar 4, 2005 | 04:05 PM
EJ2-Fluffy's Avatar
Well I havent, shouldi hook up the shift linkage and all that
Old Mar 4, 2005 | 04:09 PM
kulangot's Avatar
try it and see if that works...
Old Mar 4, 2005 | 04:10 PM
EJ2-Fluffy's Avatar
okies, hmm i should heat it up to see if i can get it out though =\
Old Mar 4, 2005 | 05:54 PM
EJ2-Fluffy's Avatar
ehm didnt work =\
Old Mar 4, 2005 | 06:06 PM
kulangot's Avatar
sorry i tired to help..
Old Mar 4, 2005 | 06:56 PM
EJ2-Fluffy's Avatar
Thanks for trying. Is there anyway u happen to move the axles ?
Old Mar 4, 2005 | 08:58 PM
Chronic_SMOKE's Avatar
put the car in neutral
Old Mar 5, 2005 | 06:03 AM
EJ2-Fluffy's Avatar
Default Re: (Chronic_SMOKE)
ahh cool will try that
Old Mar 5, 2005 | 08:46 AM
slammedcivicsi's Avatar
i couldnt get mine out either.....I tried for a bit and no luck.....but when I got my B-series it didnt have one....so I got an electronic one....but I havent wired it yet because I sold my DC2 gauge cluster....so now I'll have to go get an OEM one for now...Good luck with the removal....Let us know how it went.
-Brad
Old Mar 5, 2005 | 09:48 AM
CRX_Control's Avatar
Default Re: (slammedcivicsi)
i had a pair of vise grips and i think all i had to do was grip that thing very hard and twist it untill it got loose .
Old Mar 5, 2005 | 11:33 AM
EJ2-Fluffy's Avatar
Default Re: (CRX_Control)
hmm good one, I need to twist it. Ill go try it now. HOpefully everythign comes out so I can get this darn thing in order.
Old Mar 5, 2005 | 11:41 AM
kulangot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control &raquo;</TD></TR><TR><TD CLASS="quote">i had a pair of vise grips and i think all i had to do was grip that thing very hard and twist it untill it got loose .</TD></TR></TABLE>
that's what i was trying to say....
Old Mar 5, 2005 | 01:05 PM
EJ2-Fluffy's Avatar
Default Re: (sirq2u)
dang that mug is hard to get out. seriously im thinking of just taking out th engine again
Old Mar 5, 2005 | 05:10 PM
EJ2-Fluffy's Avatar
Default Re: (CRX-Fluffy)
My gots, there is no way to do this. Any honda gurus out there know how to pull out the speedometer gear housing?
Old Mar 6, 2005 | 04:23 AM
EJ2-Fluffy's Avatar
bump for anyone's help. I vicegripped it to death and just end up bending the housing.
Old Mar 6, 2005 | 12:03 PM
EJ2-Fluffy's Avatar
Old Mar 6, 2005 | 12:35 PM
W O T's Avatar
I couldnt get it either man, I played with it for an hour
All I was doing was swapping throwout bearings so I kind of just tried to pry the tranny away at the bottom and swap it, yeah well that didnt work, top of the tranny fell and the ******* cable broke, I now have no speedo
Im swapping another build D in shortly, Ill see if I can get it then
Old Mar 6, 2005 | 12:49 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
What I did:
1.Take compressed air and blow/clean out the dirt and debris
where the sensor is inserted..
2.Soak it liberally around the outside with PB Blaster
3.Grab the larger part of the sending unit where it meets the transmission
with some round jawed channel-locks or vise-grips.
4.Move the sending unit side to side to break the seal,reapply lube if necessary.
5.As the side to side movement becomes easier with the lube,start pulling
upward while still moving it back and forth..
6.Heat from a small propane torch might also help..
[lack of space is going to make all this very difficult]
I had never removed one until just now but the trans is not in a car
so it was not as hard I'm sure..
Old Mar 6, 2005 | 12:58 PM
88DXCRX's Avatar
Default Re: How do you get the speedomter Gear out? (88DXCRX)
You might also be able to move it up slightly using the little slot
in the sending unit that is designed to hold it in using a
flatblade screwdriver or a brake adjustment tool...
Old Mar 6, 2005 | 02:00 PM
EJ2-Fluffy's Avatar
Man i pulled it out, seems like it was dented. I had to drill tap it and put a screw in it and use a puller on it. Came out like a charm Seems the person who tried to take the cable out broke the female end of the gear, now I have to buy a new one.
Thanks for the help guys
-Jon
(*Btw you can fill the transmission fluid from here as well*)
Old Mar 7, 2005 | 07:44 AM
yes you can put fluid tranny fluid in there.
