Si Cam install questions (d15b2)
Old Mar 4, 2005 | 03:08 PM
vegaskurt's Avatar
Default Si Cam install questions (d15b2)
Im getting ready to put a Si cam in my d15b2. The haynes manual I have is not that great but it covers the basics. I was wondering if anyone has seen a good write up with pics on how to do it. And also, should I re-use the d15 cam gear or use the Si's?
Old Mar 4, 2005 | 03:20 PM
eda6's Avatar
Default Re: Si Cam install questions (vegaskurt)
what's up man? Did you get the cam out of that wagon?
Search for the crx factory service manual and download it.
Old Mar 4, 2005 | 03:25 PM
88 rex's Avatar
Default Re: Si Cam install questions (eda6)
I think you'll need an adjustable cam gear. I think it would be off by a tooth or so regardless of whether you use the b2 or a6 cam gear.
Old Mar 4, 2005 | 03:35 PM
4drEF's Avatar
Keyboard Humorist
I believe even the Haynes covers the correct positioning of the cam gear for when you put the timing belt back on.
From what I remember, the gear has 2 sets of markings on it. One set is for the D15 and one set for the D16. Just make sure you set it up for the D16.
The head casting is the same for the D15 and the D16 so I fail to see how you would need an adjustable cam gear or how the belt would be off half a tooth.
I know you are about 1/2 a tooth off for a mini-me when using the D16Z6 head.
Old Mar 4, 2005 | 03:48 PM
EJ2-Fluffy's Avatar
Default Re: Si Cam install questions (4drEF)
kkkk
Buy a helms manual
-Jon
Old Mar 4, 2005 | 03:55 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Si Cam install questions (CRX-Fluffy)
CRX-Fluffy - you aren't supposed to link or post to illegal material on the net.
Old Mar 4, 2005 | 04:14 PM
vegaskurt's Avatar
Ok, so I should install it as if I was installing it on an SI. I did read somewhere that there are two different markings on the cam gear. I just need to figure out which one.
Old Mar 5, 2005 | 06:18 AM
88 rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">I believe even the Haynes covers the correct positioning of the cam gear for when you put the timing belt back on.
I know you are about 1/2 a tooth off for a mini-me when using the D16Z6 head.</TD></TR></TABLE>
I thought you needed it b/c the block was shorter and timing would be slightly off.
I dunno.
Old Mar 5, 2005 | 11:02 AM
G2turbo_terror's Avatar
Default Re: Si Cam install questions (88 rex)
FYI-the gears have the same # of teeth. The difference in how the cam is indexed. Just sharing cause I had the two side by side once and was just like, WTF is everyone talking about!?
Old Mar 5, 2005 | 01:29 PM
efcivic757's Avatar
I put an aftermarket si cam in my old d15. What I did was made a mark on the cam gear and a mark somewhere on the block, so you can line the marks up. Slide the timing belt off by hand. Don't mess with the tensioner. Take out the cam. Used my d15 cam gear. Put the cam back in and line up the marks you made. This way everything should be lined up how it was before you took it out. Then slide the timing belt back on, without messing with the tensioner.
Old Mar 5, 2005 | 02:18 PM
SilentWrath's Avatar
yes it will be off 1/2 tooth, due to cam indexing because of block deck height
1/2 tooth = 4.75 degrees
i am currently running this setup
Old Mar 5, 2005 | 04:53 PM
vegaskurt's Avatar
Default Re: (SilentWrath)
I could of sworn the blocks and heads were the same. Just the stroke and cam were different right?? Someone school me....
Old Mar 5, 2005 | 06:27 PM
payneth's Avatar
Default Re: (vegaskurt)
anyone who has done a cam swap for the first time thought it was easier or harder than expected? any inputs?
Thanks in advance
Old Mar 6, 2005 | 02:26 AM
88 rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vegaskurt &raquo;</TD></TR><TR><TD CLASS="quote">I could of sworn the blocks and heads were the same. Just the stroke and cam were different right?? Someone school me.... </TD></TR></TABLE>
heads are the same, minus the cam.
Blocks are different in height.
Old Mar 6, 2005 | 03:01 AM
Default Re: (88 rex)
rods are 3mm shorter, pistons have 3mm less compression height and are flat top not dish, rod journals on the crank are smaller, block deck height is shorter, crank pulley has no harmonic balancing...im sure there is something i missed
Old Mar 6, 2005 | 05:38 AM
Garrett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilentWrath &raquo;</TD></TR><TR><TD CLASS="quote">rods are 3mm shorter, pistons have 3mm less compression height and are flat top not dish, rod journals on the crank are smaller, block deck height is shorter, crank pulley has no harmonic balancing...im sure there is something i missed</TD></TR></TABLE>
Yes it's 1.5L
Cuong-nutz
May 16, 2005 03:55 PM
CYBEREXII
Jul 10, 2003 03:33 PM
agent marlon
Nov 19, 2002 07:58 PM
