d15b cam?
Guest
Posts: n/a
The Y5 cam is actually more aggressive then the y8 cam. I'll be able to see which is better. the z6 bottomend with a HX head and z6 manifold on a chipped p28 or my hatch with a d15b with a chipped p28 also. Both have I/H/E. I'll take a y5 head over a z6 head in a heartbeat for OEM purposes but since the y5 doesn't have any cams i have to switch back over to the z6 if I were to get a different cam later on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egizzle8 »</TD></TR><TR><TD CLASS="quote">The Y5 cam is actually more aggressive then the y8 cam. I'll be able to see which is better. the z6 bottomend with a HX head and z6 manifold on a chipped p28 or my hatch with a d15b with a chipped p28 also. Both have I/H/E. I'll take a y5 head over a z6 head in a heartbeat for OEM purposes but since the y5 doesn't have any cams i have to switch back over to the z6 if I were to get a different cam later on.</TD></TR></TABLE>
what is the y5? and so the d15b cam does make more power on the y8 head right?
Modified by asilaydying1984 at 8:04 AM 3/7/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GapxGuy »</TD></TR><TR><TD CLASS="quote">I don't think the D15b/D16z6 cam fits in the Y8 heads.</TD></TR></TABLE>
the cams fit just timing will be off by 5 degrees or so. the y5 is the hx motor and the d15b cam is similar in specs to the zex stage 1's from what i've heard.
