d16 integra motor in a 89 CRX
I didn't know the 90 teg came with a d series???? It came with a b18a1 engine. The 88-89 teg came with the d16a1 and it will not bolt into the 4g/2g civic/crx.
http://cgi.ebay.com/ebaymotors...=WDVW
Thats what I wana put in my CRX. I e-mailed the guy and he says its in his 91 civic.
If it is in his 91 civic it is a dohc ZC engine because I know for sure the d16a1 does not bolt in and the usdm 1990 integra never came with a d16. Ask him for the engine code off of the block.
Yes if it is a dohc zc you can use your stock mounts and the si trans and axles. Depending on what model crx you have you may have to do some wiring work as well and you may also need to change the hubs.
Heavy Pee
Aug 7, 2002 03:30 AM
