Valve Adjustment Question (Already checked the search)
Old Jan 21, 2002 | 05:21 PM
Volcom's Avatar
Default Valve Adjustment Question (Already checked the search)
I'm really new at this stuff. My question is where do you place the feeler gauge? Do you check the clearance under the lob of the camshaft? I have only had the valve cover off one time and just looked around under there. I checked my helms manual and the picture really doesn't give me a good idea on where to place the feeler gauges? Any help or pictures would be great. Thanks
Old Jan 21, 2002 | 05:33 PM
yellow blur's Avatar
Default Re: Valve Adjustment Question (Alphanumeric)
stick it between the rocker arm and the cam lobe.
http://www.c-speedracing.com/howto/v...lveadjust.html
c-speed is your friend...
[Modified by yellow blur, 6:35 PM 1/21/2002]
Old Jan 21, 2002 | 06:36 PM
Volcom's Avatar
Default Re: Valve Adjustment Question (yellow blur)
thanks for the website and the pic. How do you know how much drag is enough? Just wondering. Thanks again
Old Jan 21, 2002 | 08:26 PM
uber_nihilist's Avatar
If you can't get the feeler in, then you have too much drag. Adjust the valve until you can *just* get the feeler between the cam lobe and rocker arm contact point and slide it back and forth freely. Getting used to the feeler gauges is key. Once you are used to using the guages you will be able from experience to tell when it is tight.
When I first started I was always inserting them at the wrong angle and would get them stuck, but after about 20 minutes I learned how to do it. By then I could tell between whether I inserted the guage at a wrong angle or whether the valve really was too tight or too loose.
Old Jan 21, 2002 | 09:20 PM
GRM Scott's Avatar
25 Year Member
It will be pretty obvious between too tight (won't fit in) and too loose (zero friction). Just get in there and do it, you'll laugh at how easy it is when you're done.
Old Jan 21, 2002 | 09:47 PM
mattymatt's Avatar
New User
I forget what the specs are for the required feeler guage size, but adjust the valves so that the right size fits, but the next step in size does not.
Old Jan 21, 2002 | 09:52 PM
HX_Guy's Avatar
Default Re: Valve Adjustment Question (mattymatt)
Screw that "moves freely" crap...thats what I did the first time and they were loose as hell. Do it to where it bearly fits..but still fits. If you want to double check yourselg, after you adjust it to where you want, try and get the next bigger size feller in..if its doesnt fit at all..then youre good.
BrandonClaps
Apr 27, 2005 10:06 PM
pdiggitydogg
Mar 21, 2005 05:50 PM
CardDealer
Mar 10, 2004 06:25 PM
Chubz
Jul 8, 2002 12:31 PM
Volcom
Jan 21, 2002 07:01 PM
