Oil usage
Old Mar 4, 2005 | 07:47 AM
EM2Civic's Avatar
Default Oil usage
As I was searching there are alot of ppl using 10w30 instead of 5w30 like my friend uses(99 Prelude Base). Should he switch to 10w30 considering it is thicker will it burn less oil (not that it does but h22s in general drink). He's running motul full synthetic.
Old Mar 4, 2005 | 07:54 AM
britishlude's Avatar
Default Re: Oil usage (EM2Civic)
A lot depends on the climate the car is used in, as I see your based in Quebec I would stick with the 5w 30, it offers better protection at colder temperature as it is that bit thinner below freezing than a 10w 30 oil is. If you lived in somewhere like S Cal where it's warmer, to use 10w 30 would be better in my opinion.
Old Mar 4, 2005 | 08:07 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: Oil usage (britishlude)
Newer cars - 5w 30
Used cars - 10w 30
As states, since your in Canada, use 5w-30. 10w-30 is fine also, but it takes longer to warm up. It's your choice! IMO, I'd go with 5w-30.
Old Mar 4, 2005 | 08:08 AM
Matgallis's Avatar
i thought the thicker the oil, the better it is against the cold?
Old Mar 4, 2005 | 08:13 AM
* B A N N E D *
Default Re: Oil usage (Matgallis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matgallis &raquo;</TD></TR><TR><TD CLASS="quote">i thought the thicker the oil, the better it is against the cold?</TD></TR></TABLE>
No way. Thicker oils takes longer to break down and warm up. Therefore, it takes a while to lubricate the moving parts in the engine. Which can cause engine wear.
I used mobil 1 race oil, 15w-40 in my STi once. Even after warm up, the car felt sluggish as hell. I switched back to 5w-30 and it felt normal again.
Old Mar 4, 2005 | 11:21 AM
EM2Civic's Avatar
Yup higher number thicker oil. I remember I used to run 20w50 on my oil burning d15 hatch LOL. Thanks for the replys guys i'll tell him to stick with what he's using. His block is new though it has 15,000km since honda changed it under warranty.
FoxRiderH22A
Jul 3, 2009 06:30 AM
TyPeS-TunEr
12
Mar 22, 2007 06:05 PM
K-Spec
Apr 12, 2006 08:34 PM
WPG_5thgenprelude
May 18, 2005 06:23 AM
jimbob2
Acura TL, RL & ZDX
Jan 10, 2004 10:55 AM
