Getting ready to order motor mounts, need some advice... please.
Old Mar 4, 2005 | 07:29 AM
Bbasso's Avatar
Default Getting ready to order motor mounts, need some advice... please.
I'm pretty much set on getting the Jim Fab mounts in the street version (tad softer then race), Does anyone have any thoughts or comments about motor mounts for a mostly stock R W/ bolt-ons?
Oh and yes I have looked at the inserts but since my stock ones are very shot I'd rather replace the entire mount, then just put a band-aid.
One more thing I also have Z10 traction bars on the car, would installing stiff motor mounts cause any problems?
thanks!
Old Mar 4, 2005 | 08:14 AM
Dan GSR's Avatar
Default Re: Getting ready to order motor mounts, need some advice... please. (Bbasso)
Rob, the jim fabs are nice
but u can still use inserts on broken motor mounts
$165 for all three jim fab mounts vs. $30 for ES inserts and $130 in my pocket
im gonna go with the inserts
Old Mar 4, 2005 | 08:18 AM
Bbasso's Avatar
Default Re: Getting ready to order motor mounts, need some advice... please. (Dan GSR)
I'm thinking this way... Put new ones in and never look back.
I'd rather not have <u>any issues</u> with the motor mounts again, so for me to spend a few extra $$ is fine.
Old Mar 4, 2005 | 08:27 AM
KOALA YUMMIES's Avatar
Window weld!!!!!!!!11111111 (it is a serious option though for broken mounts)
Which mounts did you break? (Im assuming the torque mounts or rear cause thats what Jim Fab makes).
Old Mar 4, 2005 | 08:29 AM
Bbasso's Avatar
Default Re: Getting ready to order motor mounts, need some advice... please. (KOALA YUMMIES)
I'm not going to ghetto anything, I'd rather spend money once and be done.
but thanks, I have looked into it.
Old Mar 4, 2005 | 09:28 AM
mstewar's Avatar
I put fairly used JDM mounts on my R when we did the motor.. Put in the inserts and have never looked back.. I'm with Dan on this one, it was $$ in my pocket..
the jim fab stuff is nice, but really not necessary if you're not building a race kaa methinks.. even the "street" version..
Old Mar 4, 2005 | 09:51 AM
Dan GSR's Avatar
Default Re: Getting ready to order motor mounts, need some advice... please. (mstewar)
I have ES front lower torque mount inserts
prothane rear, and upper tranny inserts
and will do prothane upper engine mount come spring
my bitch don't move as it is
Old Mar 4, 2005 | 09:55 AM
BlueR's Avatar
mugen or spoon motor mounts are nice
Old Mar 4, 2005 | 10:17 AM
Black R's Avatar
25 Year Member
prothane rear and uppers here (race) with ES lowers...
with traction bars it's a nice combo.....
Old Mar 4, 2005 | 10:29 AM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">im gonna go with the inserts</TD></TR></TABLE>
I went with the inserts.... no worries at all and the spare money is in my pocket.
Old Mar 4, 2005 | 10:32 AM
davidnyc's Avatar
Rob,
Save money and do inserts.
Old Mar 4, 2005 | 10:34 AM
B2FiNiTY's Avatar
Default Re: Getting ready to order motor mounts, need some advice... please. (davidnyc)
HAsport mounts
My favorite but they are quite costly when compared to jim fab.
Old Mar 4, 2005 | 10:37 AM
fullraceacura's Avatar
Default Re: Getting ready to order motor mounts, need some advice... please. (Willard)
replacing the inserts is not ghetto at all, the rubber is the only thing that would ever wear out on the mounts since the mounts are made out of steel or whatever,
either option will fix your problem
Old Mar 4, 2005 | 11:28 AM
TPB's Avatar
TPB
Default Re: Getting ready to order motor mounts, need some advice... please. (itr#xxxxlives)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr#xxxxlives &raquo;</TD></TR><TR><TD CLASS="quote">replacing the inserts is not ghetto at all, the rubber is the only thing that would ever wear out on the mounts since the mounts are made out of steel or whatever, </TD></TR></TABLE>
Precisely! My driver's side mount had split, dumping its fluid and the engine was moving considerably as a result. Replaced the insert with a Prothane race insert for all three mounts and never looked back. No need to ever replace the actual mount unless the housing is cracked or you are doing an engine swap.
Old Mar 4, 2005 | 01:20 PM
RTW DC2R's Avatar
Im just going to do a rear mount, and get inserts for the rest. That should be plenty and wont vibrate or rattle my head off.
supposedly traction bars + mounts = no wheel hop so that should be a good combo.
Old Mar 4, 2005 | 05:48 PM
euG3dc2r's Avatar
I think it's personal preference. They appear to do the same job, but in the long run, I'd prefer an actual motor mount replacement.
Where do you get the jim fab one from? I'm heading to SJ in a month and wanna organise some parts to fly back with me :D
Jim fab fit JDM?
alx_90ef
20
May 30, 2014 06:31 AM
hondaapi
Oct 20, 2008 01:52 AM
NAmodified
Oct 16, 2007 08:35 AM
Rod.
Jul 2, 2005 11:49 PM
P'nut
Dec 10, 2004 06:38 PM
