Enjo motor mounts question!?
Old Mar 4, 2005 | 07:03 AM
Marlon88's Avatar
Default Enjo motor mounts question!?
Hello Honda people
I receaved the Enjo Motor mounts OE upgrade for the integra and in the kit I got had the rear mount , the top mount near the timeng belt and the top gearbox mount , now when we got to install them we noticed that the other 2 mounts (The ones you get when you buy the inserts) the front lower ones are also bad, one of them is compleatly shot .
-Is it safe for the Enjo rear mount to take the abuse without the front mounts doing the work ??
-Can the Enjo mount take the abuse or it will go bad also ??
-Sould I buy some inserts for the front ones ??
Hasport and Enjo users , tell me what you did .
Thanks very much
Marlon
Modified by Marlon88 at 9:21 PM 3/4/2005
Old Mar 4, 2005 | 12:22 PM
Marlon88's Avatar
Default Re: Enjo motor mounts question!? (Marlon88)
anyone !!??
Old Mar 5, 2005 | 12:08 AM
GOOCH-JDM-ITR's Avatar
definately replace them if they are broken.
Factory will be fine, get the inserts if you want to rattle your teeth loose.
Other wise just install the 3 mounts you got, replace the broken ones with OEM goodness and enjoy the additional support
Old Mar 5, 2005 | 03:53 AM
Reid's Avatar
Global Moderator
I've seen a set of Enjo mounts.
I wouldn't put those on ANY car that I owned.
They're the lowest quality engine mounts that I've ever seen.
Old Mar 5, 2005 | 06:43 PM
Marlon88's Avatar
Default Re: Enjo motor mounts question!? (Reid)
Reid why are you saying this about Enjo mounts ? I have them in my car and they are realy great mountings. unless you tryed a set for your self you couldn`t say nothing about them .
I just receaved an E-mail from Enjo and I asked them the same question that I asked here and the reply was that I should have no problems running only 3 enjo mounts , they have tested them and they waranty them to handle up to 700hp , they also have a life time waranty.
Now I am going to add some inserts to the other 2 mounts and see what happens
Thanks guys for your help.
Marlon
Old May 8, 2005 | 03:40 PM
Takumi Fujiwara's Avatar
Are most of the added vibration from the lower 2 torque mounts? I have inserts on the 2 lower, and plan on upgrading to jimfabs... I'm just wondering if it'll be too nuts adding the enjo mounts.
Frickr
Nov 12, 2007 03:34 PM
gustavito1986
Mar 14, 2007 09:03 AM
Spectrum24x
Jul 6, 2005 10:34 PM
rocketfuelcerx
Jan 21, 2005 01:23 PM
Muckman
Aug 28, 2002 12:18 AM
