Small Strange Electrical Problem, maybe you know how to fix it??
Old Mar 4, 2005 | 05:56 AM
Chronicsinners's Avatar
Default Small Strange Electrical Problem, maybe you know how to fix it??
Ok, this is rather wierd, i recently moved my battery to the rear, but this problem has existed since a couple days before it, so im not sure if they are related.
Car: 90 Civic Hatc - JDM D15
Ok, when im driving, at night, i will have the high beams on and put my turn signal on, and things will start to go haywire. Like the tach will start bouncing, and the temperature guage will start to rise. One would think this is an electrical problem, like a draw problem, but when i put other loads on the system, ie defroster, heat, wipers, it doesnt do it. Any thoughts?
Also possibly related, my gas guage seems to just hover at halfmast, it doesnt really fluxuate, and i think it might be related. So any input would be great. I think it might be a bad ground or blown fuse, let me know what you think...
Thanks
-Bob
Old Mar 4, 2005 | 06:10 AM
bustah49's Avatar
Default Re: Small Strange Electrical Problem, maybe you know how to fix it?? (Chronicsinners)
sounds like you have a bad ground there bud.
Old Mar 4, 2005 | 06:41 AM
Default Re: Small Strange Electrical Problem, maybe you know how to fix it?? (bustah49)
yea thats what i think, is there any documentation on what and where needs to be grounded?? maybe im missing one or something
Thanks
-Bob
Old Mar 4, 2005 | 07:26 AM
bustah49's Avatar
check the ground by the thermostat housing...that is usually the biggest pain
Old Mar 4, 2005 | 07:27 AM
will do waldo
any1 else ever have this problem??
Old Mar 4, 2005 | 07:50 AM
doublethink's Avatar
the helms manual for the car lists all the proper ground points.
check the one by the main relay, theres one high above the gas pedal.
also where did you choose to ground the battery in the rear?
Old Mar 4, 2005 | 07:51 AM
Default Re: Small Strange Electrical Problem, maybe you know how to fix it?? (doublethink)
right on the spare tire mounting bolt (i dont run a spare)
Old Mar 4, 2005 | 08:14 AM
crxtreme89h's Avatar
Did you test that bolt for a good ground before you moved the battery back there? I would check behind your gauge cluster and below the steering column for a loose ground.
Old Mar 4, 2005 | 08:23 AM
vegaskurt's Avatar
Default Re: Small Strange Electrical Problem, maybe you know how to fix it?? (crxtreme89h)
I have a similar problem. At night, the first couple of times that I put the blinker on all the dash lights go out on me for a second or two. So I just bought some 1 guage wire and I am going to replace all the ground wires I can find in the engine bay this weekend to see if it helps.
moefoe81
Acura TSX
Oct 16, 2012 03:36 PM
AllMotorBrew
Dec 5, 2003 11:25 AM
robbin
Oct 29, 2003 07:42 PM
mattymatt
Feb 22, 2002 10:40 AM
