how can i tell.. cams and final drive
Old Mar 4, 2005 | 06:18 AM
RagingAngel's Avatar
Default Re: how can i tell.. cams and final drive (JDM97dc2R)
do the math and see if the counter/final gear gives you 4.785...
or you could count the ring gear...it should give you exactly 67 teeth from memory.....
The countershaft also uses a distance collar.
EDIT: More info from my 4.9 FS thread long ago: https://honda-tech.com/zerothread?id=464078
Standard 4.400 ring gear = 66 teeth
JDM 4.785 Final Drive = 67 teeth
ATS 4.9 Final Drive = 69 teeth
also parts you might need if you are putting it into a 96spec tranny
1st gear 23421-P80-E30
Distance collar 23914-P80-E30
Needle bearing 91107-P80-E31
I'm in HK too...what part are you from?
Modified by RagingAngel at 7:51 AM 3/4/2005
Old Mar 4, 2005 | 06:43 AM
1999all_motoR_teg's Avatar
Default Re: how can i tell.. cams and final drive (RagingAngel)
On an OEM ITR tranny with the 4.785 final drive there should be a stamp saying N3E LSD in black ink. If it says J4D LSD then it has the 4.4 final drive.
Unfortunatly the stamp may have rubbed off, so the only other option is to open it up and count the teeth as stated above.
EDIT: reading ownz me. You are just purchacing the final drive so yes you should count the teeth. my bad
Old Mar 4, 2005 | 06:47 AM
JDM97dc2R's Avatar
Default how can i tell.. cams and final drive
ok i am living in hk im going to buy some cams and also a final drive how can i tell if the final drive they are selling me is 4.785 OEM HONDA is there any marks? or writings?
and also im planning on buying second hand JUN3 cam is there any markings? or writings so i can differentiate that is a jun3 cam?
Old Mar 4, 2005 | 06:48 AM
JDM97dc2R's Avatar
and also what are the things i should look when buying the cams
Old Mar 4, 2005 | 08:01 AM
JDM97dc2R's Avatar
hey raging angel that is cool that u are in hk can we talk someday to see where can i buy things for my car? im new here in hk
turboITR#704
Jul 22, 2007 10:31 AM
thorshammer56
Honda Motorcycles
Jun 6, 2007 08:05 AM
DARKTEG_
Aug 19, 2006 06:56 AM
Dual Cams
Jan 23, 2003 12:16 PM
slofu
Sep 4, 2002 02:05 PM
