water and oil pump
Old Mar 4, 2005 | 12:33 AM
civicswap's Avatar
Default water and oil pump
Im planning on building a ls vtec but until I have the money Im just gonna finish the block and use the ls head. I was wondering since I already have the motor out if I would
be able to use the gsr water and oil pump without a vtec head?
Old Mar 4, 2005 | 12:45 AM
Terrible One's Avatar
Default Re: water and oil pump (civicswap)
*bump* would like to know also
Old Mar 5, 2005 | 12:04 PM
civicswap's Avatar
no one has an answer?
Old Mar 5, 2005 | 12:35 PM
NJIN BUILDR's Avatar
Oil and water pumps will work fine.You will need to use the gsr timing belt.The gsr water pump has more teeth.
Glenn
Old Mar 5, 2005 | 12:58 PM
civicswap's Avatar
Default Re: water and oil pump (NJIN BUILDR)
can I use it with ls head?
Old Mar 5, 2005 | 01:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicswap &raquo;</TD></TR><TR><TD CLASS="quote">Im planning on building a ls vtec but until I have the money Im just gonna finish the block and use the ls head. I was wondering since I already have the motor out if I would
be able to use the gsr water and oil pump without a vtec head?</TD></TR></TABLE>
Yes.You said you were using ls head.The gsr pump means you need the longer (gsr) belt.
Glenn
Old Mar 5, 2005 | 04:04 PM
civicswap's Avatar
sorry just wanted to be sure thanks
young geezer
Oct 1, 2011 12:21 PM
k20o2o4civic
Aug 30, 2006 01:12 AM
GEN2INTEG619
Mar 27, 2005 04:57 PM
dabrown
Jun 25, 2004 02:43 PM
tegasaurus
Aug 10, 2003 01:07 PM
