IDLE thread...
i know this might not sound right, but check the throttle cable.. see if it stretched out or not.
I had somewhat the same problem. even got a engine light for eacv problem. Took ti to Acura and they said my throttle cable streched and they re adjusted it. Hasn't done it yet.
i found it odd, but you never know!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shinobijesus »</TD></TR><TR><TD CLASS="quote">uh, whats an IAC?
and again, anyone with an idle problem post it up.</TD></TR></TABLE>
Idle Air Control Valve. My high\low idle was caused by the FITV (fast idle thermo valve) just screwed the plastic piece back in and the problem was solved.
thanks for the new ideas swanny and quick_ls.
no one else got an idle problem right now? hmm, thanks for the help though yall.
oh and about the weird drop in rpms while i idle it higher manually, its actually like a 2-4 hundred rpms fluxuation not 100 like i previously thought.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 civic VX B18c »</TD></TR><TR><TD CLASS="quote">I'm currently having the exact same problem</TD></TR></TABLE>
whoa. if you get it fixed before me let me know whats up.
whoa. if you get it fixed before me let me know whats up. </TD></TR></TABLE> Well it turns out I sucked up a few little styrofoam packing peanuts into my IACV my buddy Chris(CBAracing) took it off yesterday and found them for me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 civic VX B18c »</TD></TR><TR><TD CLASS="quote"> Well it turns out I sucked up a few little styrofoam packing peanuts into my IACV my buddy Chris(CBAracing) took it off yesterday and found them for me</TD></TR></TABLE>
hmm, that would be crazy if the same exact thing happened to me so i kinda doubt it but ill keep that in mind.
hmm, that would be crazy if the same exact thing happened to me so i kinda doubt it but ill keep that in mind.</TD></TR></TABLE> I would recomend taking your IACV off and checking the little scean in it for debris
lsxtreme81
Apr 20, 2007 05:39 PM
