daitime running lights problems
Old Mar 3, 2005 | 06:13 PM
a320's Avatar
Default daitime running lights problems
I bought a 92 accord LX, Since day one the DRL wouldn't work. I trace the problem to the right side high beam head light, replaced the bulb that didn't fix the problemand I believe the problem is a bad grownd because on really hot days after driving for about half hour the daitime running lights will start working.
My problem is I can't find the ground to clean it and fix the problem, if any one knows where I can find a wire schematic for the 92 accord I would appreciate it.
Thanks
Old Mar 3, 2005 | 06:19 PM
Nathan007's Avatar
I cant give you schematics, and im not sure if your problem is related to mine, since i have a 94 accord.
I too had a DRL problem, to make it short,the problem was inside the DRL CONTROLE MODULE, a little box under the drivers side dash..(for my accord year) You open it up, there will be some soldering that have cracked.. Re do them using a Electronics Welding tool, there you go!
Old Mar 6, 2005 | 10:04 AM
a320's Avatar
Default Re: (Nathan007)
THANKS FOR THE ADVICE, I yest read your mail and I am going to try it today, I let you know how it went, thanks again.
dfbdavid38
Jan 26, 2011 08:54 AM
2004accord
Dec 5, 2004 05:52 AM
