How Much Hp will you think ill get with this set up
my car is currently being built. i drove it before without the stroker kit and the built head. i did researches on b20 franks and there were cars on this site with less mods than mine with huge numbers. http://www.importreview.com/d_2.0.html
should i expect less or more? there are some ppl that say b20 franks put out 200 hp with stock parts others say less than that.
all of this is in a 1999 Civic SI
Engine Mods: (B20Vtec) Built 98 CRV Block, 99 SI Transmission, 99 SI ported & polished head, Crane Stage 2 Cam Shafts, Super Tech valves, Super Tech Dual Titanium valve springs, Super Tech Titanium retainers, AEM Tru Time Adjustable Cam Gears, Apexi Vtec Controller, AEM Short ram intake, 70mm Throttle body, Skunk 2 Intake Manifold, NGK Spark Plug Wires, Zex Plugs, AEM Fuel pressure Regulator, JE Stroker Kit ( JE 11:1 Compression Pistons, Eagle Rods, Eagle Forge Steel Crank),Golden Eagle Oil Line Kit, Jegs Fuel Pressure Gauge, ACT Street Light 12lbs Flywheel, ACT Stage 2 Xtreme Pressure Plate Clutch, DC Sport 4-1 Headers, Hi-Flow Cat,Greddy Evo Exhuast System, Pro 1 Short Shifter, Enjo Urethane Motor Mounts
Exterior: VIS OEM Carbon Fiber hood, VIS Carbon Fiber Trunk, R34 front bumper, Blitz Sideskirts, Buddy Club Rear
Interior: Mugen Steering Wheel, SPW Air Fuel gauge, SPW Oil Temperature gauge, AC Autotechnic S7 Dimensional Gauges, AC Auto Technic 3d Bezel, Type R Shift ****, Razo Mirror
In Car Electronics: Pioneer Head Unit, Rockford Punch 12' Sub, Rockford Punch Amp
Suspension: Tokico Shocks,SI Strut Bar, Weapon R Adjustable Coilovers
Rollers: 17 ' R1 GTR 10s (Black w/Polished Lip) Ventus Sport K104 Tires
http://www.xanga.com/hybrid_syndicate
All motor thread rule #3
3. Guess my HP/1/4 mile threads.....
will be deleted. We aren't here to guess...take it to a dyno or track.
you will make 100,000,000,000 hp.....for sure
or you could take your money you put into your car and GET IT DYNOED
PLEASE READ THE RULES
Modified by B18TurboEF at 9:48 PM 3/4/2005
if ur gonna be a jack *** about it how about you not answer the question read the question carefuly im trying to get an estimate the car will be dyno'd after i get 500 miles on it so i can hook up the vtec controller
i have these parts for sale if anyone is interested
All Items Are Negotiable. Just Make an Offer!!!
99 SI Steering Wheel
99 SI AEM Fuel Rail
99 SI Intake Manifold
99 SI Flywheel
99 SI Cam Gears
99 SI Knock Sensor
99 SI Coolant Temp Sensor
98 CRV Head
98 CRV Intake Manifold
98 CRV Crank
98 CRV Pistons & Rods
98 GSR Cam Shafts
98 GSR Dual Valve Springs & Retainers
00 + Celica Custom Fitted Leather Seat Covers (Black & Blue)
00 + Celica TRD Spoiler
00 + Celica Carcept Roof Spoiler
99 SI AEM Fuel Rail
99 SI Flywheel
99 SI Cam Gears
99 SI Knock Sensor
98 CRV Head
98 CRV Crank
98 GSR Cam Shafts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIinDisguise »</TD></TR><TR><TD CLASS="quote">if ur gonna be a jack *** about it how about you not answer the question read the question carefuly im trying to get an estimate the car will be dyno'd after i get 500 miles on it so i can hook up the vtec controller
sorry i didnt sugar cote my answer.....but i have seen you post the EXACT COPY of what you just said in AT LEAST 4 OTHER PEOPLES THREADS trying to get the same answer.....and more than anything IT IS A RULE that you dont post these type of threads.....so actually you are being a dick by wasting a spot in the all motor forum, im just going to not respond in here anymore so it will fall.....
good luck with the setup though
</TD></TR></TABLE>sorry i didnt sugar cote my answer.....but i have seen you post the EXACT COPY of what you just said in AT LEAST 4 OTHER PEOPLES THREADS trying to get the same answer.....and more than anything IT IS A RULE that you dont post these type of threads.....so actually you are being a dick by wasting a spot in the all motor forum, im just going to not respond in here anymore so it will fall.....
AHM
Dec 5, 2008 05:44 PM
RippSpeed
Dec 20, 2007 11:53 PM
