Do all B series hydo trannies use the same synchros???
Old Mar 3, 2005 | 05:23 PM
SpeedDreamz.com's Avatar
Default Do all B series hydo trannies use the same synchros???
Do the b16a2 tranny and the gsr tranny use the same synchros?
Old Mar 3, 2005 | 06:40 PM
acy76's Avatar
Default Re: Do all B series hydo trannies use the same synchros??? (SpeedDreamz.com)
I believe they do. The VTEC transmissions should be the same; the LS versions don't have the dual cone 2nd synchro, but the others are probably common to all b-series gearboxes.
For VTEC transmissions: the part numbers for the 1-2 and 5-R sleeve sets are the same for the Si, GSR, DelSol VTEC and ITR. The 3-4 sleeve numbers match for all except the GSR (Honda will only sell it as part of a larger set, but I suspect it's the same part). Synchros should be identical.
Old Mar 3, 2005 | 07:31 PM
Kendall's Avatar
Default Re: Do all B series hydo trannies use the same synchros??? (acy76)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acy76 &raquo;</TD></TR><TR><TD CLASS="quote">Honda will only sell it as part of a larger set, but I suspect it's the same part.</TD></TR></TABLE>
Yes, in order to get any synchro you have to buy the corresponding gearset. I'm wondering if Gearspeed will sell individual synchros though.
Old Mar 3, 2005 | 07:41 PM
B20TDC2's Avatar
Default Re: Do all B series hydo trannies use the same synchros??? (Kendall)
gear speed does sell syncros by themselves i believe its like 250$ for the whole set
Old Mar 3, 2005 | 08:37 PM
vaporboy12's Avatar
Default Re: Do all B series hydo trannies use the same synchros??? (B20TDC2)
i can get all oem syncros for $230
Old Mar 4, 2005 | 10:41 AM
Default Re: Do all B series hydo trannies use the same synchros??? (vaporboy12)
This is the setup for the 2000 Si. i just wonder if it is the same for the gsr? Item #7
http://www.hondaautomotivepart...SHAFT
Old Mar 9, 2005 | 07:00 AM
AllThrottleNoBottle's Avatar
I'm in the process of rebuilding my gsr tranny, does any body know a good place to buy syncros and bearings? thanx alot
neo_
Oct 24, 2007 06:02 AM
slambedcivic
Dec 22, 2005 01:02 PM
Mista Bone
Jan 10, 2004 11:41 AM
Full-Race Henry
12
Sep 12, 2003 11:49 PM
